Morning all!
Could someone please tell me how deep the collet reducer from musclechuck sits in the collet?
Tom
Tom
Thanks,Jon. Really appreciate that!Tom, appreciate the reply. I checked my reducer and in round numbers it is 1.3" long with both the top ring and the raised area below it being .1" each. Based on the comment you recoevied from Musclechuck that the reducer should be .3" above the Chuck it sounds as though my approach is incorrect. I will continue to clarify this with the company and advise. It is unfortunate that the instruction sheet does not clarify this point.
Tim, I received a reply from Joe DeRosa and he confirms with a photo that the reduction collet should only be inserted to that first ring. Regrettably, if their video showing the correct insertion of the reduction collet was available years ago I never found it. Hence I shelved that part. Time to dust it off and create some router dust.Thanks,Jon. Really appreciate that!
Thanks a lot JonTim, I received a reply from Joe DeRosa and he confirms with a photo that the reduction collet should only be inserted to that first ring. Regrettably, if their video showing the correct insertion of the reduction collet was available years ago I never found it. Hence I shelved that part. Time to dust it off and create some router dust.
cheers
Jon
Thats awesome Jon! Good deal!Tim
just an FYI,based on further discussions with Joe DeRosa, he has kindly offered to evaluate my MUSCLECHUCK, insert combination and either repair or replace the pair as they deem appropriate.
The firm has always been lauded for its customer service and I am pleased to see that it is continuing.
Regards
jon
