1 - 20 of 43 Posts
Discussion Starter #1
Just some snapshots of my shop and the backyard b/4 the show comes aging this year..
WOW, that is nice Bj, I envy you. Had I been into woodworking when I bought this house I would have shopped smarter. Perfect set up. I now see what you were talking about the back room for storage as well. Pretty cool. Lots of room. Just taking a break while the floor guy is here making his template for tomorrow :)
Discussion Starter #3
Thanks Corey
When I got this house it didn't have the garage in the back and that was one of the 1st. things I did,,,I built the shop, then a ran out of room so I did a small add on now I wish I made it just a bit bigger,I took out a windows and some of the wall for the door way and made it 8ft x 20ft and it got filled up real quick with STUFF :) the other garage on the house the BOSS owns :) but I'm starting to put stuff in it like the Bike,Snow Blower,Tracker,Lawn Mower,etc. and my sons junk :) that he will not take to his house :) :) I thinks it's called free storage at dad's :)
Don't work to hard on the kitchen bud
Very nice Bob, thank you...
In some ways, it reminds of Niki's garage... the way he efficiently puts everything away close to the walls to allow for space in the center.
What kind of TS is that on the rolling cabinet? Looks rugged.
Oh, how did you get your dog to always pose with its head always pointing in the same direction? :) (seemed like it anyway).
I also see that you are cramped a little here & there... I'm more cramped here & here & here...
Discussion Starter #5
Table Saw is a old Atlas cast iron...my other one is under the plastic, the dog is my buddy and she will just watch me all the time, she thinks that's her job because we don't have any sheep for her to heard.. so she heards me all the time :) a lillte nip on my heel from time to time..like when I want to get in my truck, it's game for her and me too sometimes :) she is a great dog and my best friend .... :D
Bj, that's no shop - it's an aircraft hangar compared to my wee place! Guess you need the vicious looking hound to protect the tools ;)
Good Gosh Bj..... you got a few tools don't ya? I am still looking around to see if I can steal any of your ideas :D Got jigs hanging on every wall just like you said and mine is starting to look the same way. That HF BS sure looks familiar. How do you like it? Mine has done extremelty well.
All I can say is that I am jealeous of all that space packed with neat stuff :cool: Nice landscaping all around also. I sure hope that's not kudzu taking over that building ;)
Discussion Starter #8
Hi nzgeordie
At one time I did raise Dobermanns and they did the job :),, but now I just have my buddy and she is a good guard dog :) and the lawyers don't know my name...with her around..like they did with the dobermanns.. :)
http://en.wikipedia.org/wiki/Dobermann
Discussion Starter #9
Hi Bob
If you can steal it pls. do that's why I have them :)so other can use them also.
"HF BS =great I like them and do work well
kudzu= One is a Ivy and one is something I don't know what it is, it's green all year around like a pine tree vine and very slow growing ,that plant is about 25 years old and just in the pass year it got big and took over some of that wall with the ivy on it..
The leaves are a bit waxy to the touch...
Bob, speaking of the HF BS (Harbor Freight Band Saw). What kind of table and fence assembly are you using? Maybe if you have time ? and can move some of your many tools out of the way. Would you post some pics of the table and fence PLEASE. I would appreciate it.
Discussion Starter #11 (Edited)
Hi Dave
Will do,, the top is some 3/4" MDF and the 6" tall fence is the same,,
It's about 4" bigger than the steel base plate, with slots for the miter and the circle pin jig that I use from time from time..to cut big circles out..
Note***I should have made it just a bit bigger..:) all the way to the upriser and 4" over hang all the way around...you may want to do that...
Discussion Starter #12 (Edited)
Hey Dave
Here's some snapshots of the band saw...
What took so long ??????????????????????????????
Darn Bob, what took so long to get the pictures I asked for???????????? :(
Thanks Bob for the pictures. I wanted to know how you mounted the table and fence. I like how you did it. :D Nice job. Question: how do you keep the center pins from moving when you cut circles? :confused:
Discussion Starter #14 (Edited)
Hi Dave
You'er welcome
Center pins are Allen set screws, the long one is just screwed down with a allen hex key the cone point one is just hand tighten down in place and will stay in place ,the Hvy,duty one as a place for a short Allen set screw on one end that's is screwed down once you have it set in the right place in the add on board. ( the add on board I use is 4 ft long with a tee slot running all the way down the center..)
NOte on the set screw, I use 5/16-18 set screws and then ground them down to 1/4" OD but not all the way they need to screw into the sq.nuts.. :)
I used a battery power drill to grind them down,it's quick and easy to do..just pickup a rod coupling nut (5/16-18) , put in a set screw in one end and put the center pin set screw in the other end and lock it in place then just chuck up the coupling nut and do a bit of grinding to remove the threads...down to 1/4" shank size.
The black banding strap in the tee slot will help,it's very thin and very strong and you can find tons of it in trash cans.. :) (Don't use the plastic type,it will crack the 1st time you use it ) but you will need find the narrow banding or you will need to cut it down to size, it's needed in the slot because you need to band saw a slot in the new base board to get the board in place and slide by/pass the blade..
BIT ▼
Key Hole Cutting Router Bit or T-Slot Router Bit for tee slot
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_keyhl.html#T-slot_cutter_Anchor
Discussion Starter #16
Hi John
I didn't know I had a ray gun ,, :) run your mouse over the picture and a number will pop up , then post that number so I can see what you are talking about :) and we can get on the same page ...
JEBishop said:
BJ
Saw in one of the pics, what do you use the ray gun for?
John
Discussion Starter #17 (Edited)
Hi John
I think you are talking about this one :) :)
The only RAY gun I have is the Low Tech one below, but it's also a High Tech broom , it makes small things disappear out the garage door :)
3th and 4th snapshot below
Discussion Starter #19
Hi Corey
I wish I had one sometimes to empty the trash and a transporter so I could put some of the stuff some where other than in my shop and then zap it back when I needed to used it .
challagan said:
Ha ha... that's what he actually has been using to do Tom's templates you cheating #^%@#[email protected]% you ha ha.... Every one needs a good Ray Gun in the shop :)
1 - 20 of 43 Posts
