Paul I sure could have used those years ago when I was stacking roofs to hang the cords and skilsaw on. might have saved a few wormdrives from early retirement.Herb, make your own. I've seen your lock hasps, this would be similar.
I have to agree with Herb. Yes, you could make them, but the cost of the materials and your time, if you would choose to add that, may not be cost effective. High impact, injection molded plastic has a tendency to be very strong, and deterioration resistant. The cost of the Velcro straps (not just strips of Velcro) are not cheap, either.Paul I sure could have used those years ago when I was stacking roofs to hang the cords and skilsaw on. might have saved a few wormdrives from early retirement.
I would make them out of BB plywood, but I bet the cost would be more to make than buying the webbing and making them your self. Might not be as strong either.
The problem I see is using them on larger plastic liquid containers. These can become very flimsy as the liquid (and the pressure inside) lessens. The straps may become loose and lose their grip on the container.
Still a pretty neat idea and open to a lot of uses.
Some kind of rubberised backing on the straps would help there. Don't know whether they have something like that.The problem I see is using them on larger plastic liquid containers. These can become very flimsy as the liquid (and the pressure inside) lessens. The straps may become loose and lose their grip on the container.
Oh my, I screwed up. I helped someone. LOL Well, I figure stuff like that is made to please the designer, but they usually don't please me, which is one reason for making my own version, that and it's more fun making my own. I can think of several options for taking in the tea. One is NOT fastening the tea carrier, or whatever, to one of your canes. I've found that carrying something at the top of my cane throws the cane way off and it is harder to maneuver. If you have a walker that you lift and move, then I would think that is not going to do well either. However, if you have one of the walkers with wheels, I think that would have great potential. But, if you want something a bit classier, I think a small wooden tea caddy on wheels should work. I know when I go to a store and use a shopping cart I actually do better than if I used my cane - can lean on the cart when I get a bit tired or stop to look at something, and when I walk use both hands on it. So I think a wheeled tea caddy/cart might work. On the other hand, might well be easier to carry the tea in a thermos, in a cloth carrier with a strap that will go over your head and be carried on the opposite side. I would advise a non-breakable cup and saucer tho, you could make a satchel to carry those, and the thermos. No need to sew anything, awhile back I made a pretty fair size laundry bag, to carry my stuff to my son's to wash while my washer is not working, and made the entire thing out of old denim pants, and held with Titebond II wood glue. Holds together just great. I've patched holes in pants and jackets with patches and Titebond, and as long as you don't pull on the patch when it comes out of the washer, it will be as strong as ever once it comes out of the dryer. I've got stuff several years old still holding up very well.@JOAT,Should have read your reply re making a similar gadget before I sent an Email asking if it is available in Australia. I take a cup of tea in for Mrs.jj every morning & am having to stop doing this unless I can use my "walker".I use two walking sticks all the time except for the wife's tea-in-bed ritual so a handle attached to my walker should work o.k. I should have also said at the beginning that using one stick while carrying anything in the other hand is extremely hard to tolerate ,and getting worse.Thanks Theo.James
