1 - 9 of 9 Posts
I'm making a 48"x21"x16" blanket chest and want to make dovetails along the 21" joints. My router bits have a 1/2" shank and need to cut through 7/8" thick maple wood. The spacing between cuts maybe variable or fixed.
What cheap dovetail jig would you suggest? This will be the only dovetail work for me so cheaper the better.
Thanks,
Phil
Sommerfeld's Tools for Wood - Dovetails Made Easy with Marc Sommerfeld - Part 1 - YouTube
Sommerfeld's Tools for Wood - Dovetails Made Easy with Marc Sommerfeld - Part 2 - YouTube
Thanks,
Phil
Porter Cable's 4216 jig is maxed at 12", but the templates can be board mounted and moved to make dovetails as wide as you want. Seems like MLCS templates are similar, but may be limited to half-blind as i recall.
earl
Thanks,
Phil
here ya go...
Leigh D4R Pro Dovetail Jig and Box Joint Jig
here ya go...
Are you suggesting a $599 jig is cheap?
Thanks,
Phil
No luck on 1/2 in bits, but cheap and any width can be done on this jig. Hope this helps. Its for darn sure real cheap, even cheaper on Amazon ($39.97). I did not watch all the videos but what I did watch was interesting. I think all you would need is a 1/4 collet for your router. I would definitely test on scrap before putting to good wood.
Edit: MLCS does have 1/2 inch shank dovetail bits, I overlooked them before.
Forgot to post link, duh.
http://www.generaltools.com/-860--EZ-Pro-Dovetail-Jig_p_1236.html
http://www.amazon.com/General-Tools...59880183&sr=1-1&keywords=general+dovetail+jig
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bit_dovetail.html
1 - 9 of 9 Posts
