Hi. I have an old 5 ft. dia. oak table top that I so far have been unsuccessful in finishing. I want to use a satin varathane; the problem is that it has a large carved out (or routered) section in the center of the top; the varathane drips into the carved areas and when I try to brush the excess out, it ruins the smooth, with the grain surface I am trying to achieve. I thought about trying to begin at the center with a smaller brush, then working with a larger brush, with the grain to the edge and going around the table in that fashion (instead of going completely across the whole diameter as I did originally). The problem is that when I get around to the beginning point, the varathane there will be more dry. Would it leave an uneven noticeable area where the drier and wetter areas join? Is there any way of solving this dilemma short of having it professionally sprayed? Is there something I could fill the carved out areas with, that I could later remove when the top is dry, to keep the varathane from dripping in? Thank you so much for any help that can be offered. (Photo inserted.)
