61 - 80 of 96 Posts
· Registered
Good to hear, MT. Missing files, if no one intentionally deleted them, are usually caused by them being in use when the power goes out or the PC is shut down without closing a running program. The file allocation table looses track of where they are on the drive.
A re-format of the hard drive and fresh install of OS and programs is usually the best way to get it all working again, but I'd trust probotix to have taken care of what was needed to be done.
4D
· Super Moderator
Discussion Starter · #63 ·
Not being a Linux guy, is there software that will clone the hard drive? I sure would like to have a backup if there is a next time.
I have Acronis and a Nexstar USB3.0 hard drive dock that I have used on Windows hard drives.
· Registered
A quick google search found this: 4 Methods To Clone Your Linux Hard Drive
I haven't personally used any of the mentioned methods, but hopefully one will help you get it done.
4D
· Super Moderator
Discussion Starter · #65 ·
Well, dammitanyways!
I got the PC back today, plugged everything in and turned it on. It won't boot! Same as before, it starts the boot sequence, the screen flashes the OBUNTU screen, then stops at the login prompt. This really pizzes me off. They said it was working just fine.
· Registered
Can you type in "probotix" with no quote marks? At one time I bought a number keypad that I hoped I could use with the PC and every time I plugged it in the system would throw me back to the same login prompt.
It may be that one of your USB accessories (mouse or keyboard or gamepad) has gone bad and is causing the same problem. Try unplugging them all then rebooting. If you get back to the desktop screen then plug them in one at a time to see if each works or throws you back to that login page.
· Super Moderator
Discussion Starter · #71 ·
Holy Krap, Batman! IT'S ALIVE!!!
I brought the PC, monitor, mouse and keyboard into my office and hooked up spare power and a video cable. Turned it on and it fired right up! I connected the mouse and rebooted. Fired up again! I connected the keyboard and rebooted. Fired up again. Yipeee!
So I took the hardware out to the CNC and hooked up everything again. It would not boot!!! Pulled everything off except for the video cable and the power cord. Same thing - no boot. I replaced the power cord with the one I had tested it with. Still no boot. HMMM...As I stood there scratching my aching head, I realized the only thing left was the video cable. So, I replaced it with the spare from the office. VOILA! It booted right up.
A damm video cable. Who would have thunkit!
So now, I have to put everything back in its place and hook up the controller and see if it will operate as it should.
All I can say is thank you everyone for all the suggestions and advice. I can keeping my fingers crossed that the controller will work OK. I will find out in a little bit.
· Super Moderator
Discussion Starter · #74 ·
OK. More troubleshooting needed. I can navigate the control screen, but get an ESTOP error whenever I try to home the machine. Obviously it won't move and wasn't in ESTOP when the power failure occurred.
I can't clear the ESTOP. I toggled the button, and toggled using F1, but nothing happens. The keyboard seems to be working OK. I can move around using the arrow keys when I have the files folder open. And F3, F4, F5 all seem to work OK.
The machine isn't up against any of the limit switches. Seems to be a communication problem. I guess I will dig in the spare parts drawer and see if I can find another parallel port cable, and a USB cable.
· Super Moderator
Discussion Starter · #76 ·
OK. It's working now. Maybe next time I will take a picture of which LPT port the cable is connected to on the PC! :surprise::frown: SMDH! Mine has two.
Time for the ten o'clock news.
Hopefully tomorrow I will get to sling some chips. I have alread been moving the cantry around and the control board is looking good, so yeah, I would say there was a communication problem! :grin:
· Registered
Rick
These cnc router tables don’t sound like a real cakewalk some days :(
Glad to hear your back in business Mike . Strange how cables go bad like that . If seems as though if it’s not a parallel port cable , it’s a video cable
61 - 80 of 96 Posts
