New to the forum and hope you can help. I have retired so everyday is a Saturday and I've finally found the time to build a CNC Router. But have hit the fog on selecting a controller card for Mach3. I have experience in CNC, previously had 4'x8' Laser (WinCNC) and with Autocad. Never used Mach3 but looks like the best fit for me for this build.
I have 1 more day to finish the mechanical phase of the build. Its been a blast, other than not having an end mill for milling and drilling, it's been no problem. I purchased and used the following components:
- 6060 ext Al and AL plate
- Dual 1000 mm (Y) 800mm (X) 300mm (Z) linear rails with 1605 ball screws.
- 4 ea. Nema 23 425 oz steppers and DM542T drivers.
- 3.3 WC Spindle w VFD.
- 2 ea. 48-350-7.3 power supplies, to be wired in series to run @ 45v
-. 24v power supply (control)
Now I'm at the Control Panel phase and stuck on selecting a controller card.
I have looked at several Mach3 controllers and was considering the Wasp9 Ethernet or UC400 5lpt .for Eth communication and smoothstepper. But cost is high and I can't visualize how to wire the up. If I had the Gecko 540, a ribbon cable would quick and easy but I already have the DM542T so will need to add breakout boards to wire them in. Adds cost and I have not seen a clear diagram defining pinnouts. Never understood parrellal ports.
I've looked at the C94, which clearly IDs the wiring but high cost and I'm not sure if it is a smooth stepper.
Openbuilds has a CnC4 USB, at $89, better price and provides clear pin locations but looks to be limited in future expansion and is it smooth stepper?
Eventually, in addition to add motor, VFD, Limit(home/end) switches, i would like have the card controlling:
- remote Pendent
- relays for Dust Collection & Water Pump
-. Possibly add a 5th axis Rotory & touch pad.
greatly appreciate you time and hope you can shed some light to keep me on track to make some wood chips....my wife hates finding a trail in fine Al specs in the house!
Thanks, DanR
- remote Pendent
Thanks, DanR
