I have several routers, two are Sears and one is a Ryobi model 160U. I honestly don't remember why I got the Ryobi but it was probably for use with bits that had the roller bearing guides. The Ryobi is an old model but it is easy to adjust the height and I would like to use it for routing with a guide bushing but there is no guide bushings available for it from Ryobi. Is there a universal base plate I can get that will accept small guide bushings or do I have to make one? I'm cutting small parts on a jig I built and the bigger Sears router is a true pain to adjust and the smaller one might work but I have it mounted in a table for cutting work. The Ryobi router has 4 base plate screws where the others have only three. I believe I could make a Ryobi 160U base plate that will accept the guide bushing for the Sears router but I sure wish I could find a factory made one or a universal one that will fit. I can't afford to buy another router being long time retired.
Thanks in advance for any help or info,
Charlie
Charlie
