OK. This job is complete.
Let me just say I think I don't like plastic! I decided to slow the speed of the Bosch as slow as it would go, which is about 8K. The problem I ran in to was drilling the holes of my project. Even though I used the "pecking" method and had it set to retract out of the hole each time, it still melted some plastic and I had to stop and clean the bit, then start over. For what I am doing, it will be OK.
What the heck is that anyway, you might ask? Well, I have been developing
Home Assistant on a raspberry Pi. I wanted to install a sensor to let me know if the freezer door has been left open. The problem is the gasket is too thick so I couldn't mount both pieces and have the sensor work. The reed switch needs to be no farther from the other piece than 1/2 - 5/8 inch. Note: I have been bench testing the sensor and it works perfect. If the door is left open for 90 seconds, I will get a notification on my computer screen and one on my phone that the door is open. :surprise::grin:
I used double sided tape to mount the sensor, but the adapter I created has holes that can be used if needed when mounting it in other locations. I may have to go buy another cutting board if I need to make any more. :grin:
I also have a second set of adapters to use with another sensor. If I can get it to work on the garage door, that will be great. Or, install it on the storage shed in the back yard. That will get done soon.
Here are some pics. Mixing my woodworking/CNC skills with home automation. :grin::grin::grin:
BTW, it took longer to sand the fuzzies off the pieces than it did to cut them out! :frown:
Anyway, another project complete. Hope you like it.
