Hello everyone, I've had a 3018pro for a little over a week now. I was able to sucessfully carve a few things. I haven't changed any settings and now I am having issues. I am attempting to cut out someone's family name, it seems to start off fine but then somewhere along the way things go wrong. I have the starting point in the front left corner but when everything starts to go wrong I end the job and it goes back to it's homing spot, but it is about 1/2'' off. Any help would be appreciated! I have lubed the railed with dry moly lube. As you can see in the picture the hole for the letter E is off and then the bottom of the name doesn't match the top half. I am creating these in Easel, exporting the g-code, then using UGS to run my CNC.
G-Code:
$1 = 25 (Step idle delay, milliseconds)
$2 = 0 (Step pulse invert, mask)
$3 = 2 (Step direction invert, mask)
$4 = 0 (Invert step enable pin, boolean)
$5 = 0 (Invert limit pins, boolean)
$6 = 0 (Invert probe pin, boolean)
$10 = 1 (Status report options, mask)
$11 = 0.010 (Junction deviation, millimeters)
$12 = 0.002 (Arc tolerance, millimeters)
$13 = 0 (Report in inches, boolean)
$20 = 0 (Soft limits enable, boolean)
$21 = 0 (Hard limits enable, boolean)
$22 = 0 (Homing cycle enable, boolean)
$23 = 0 (Homing direction invert, mask)
$24 = 25.000 (Homing locate feed rate, mm/min)
$25 = 500.000 (Homing search seek rate, mm/min)
$26 = 250 (Homing switch debounce delay, milliseconds)
$27 = 1.000 (Homing switch pull-off distance, millimeters)
$30 = 10000 (Maximum spindle speed, RPM)
$31 = 0 (Minimum spindle speed, RPM)
$32 = 0 (Laser-mode enable, boolean)
$100 = 800.000 (X-axis travel resolution, step/mm)
$101 = 800.000 (Y-axis travel resolution, step/mm)
$102 = 800.000 (Z-axis travel resolution, step/mm)
$110 = 1000.000 (X-axis maximum rate, mm/min)
$111 = 1000.000 (Y-axis maximum rate, mm/min)
$112 = 600.000 (Z-axis maximum rate, mm/min)
$120 = 30.000 (X-axis acceleration, mm/sec^2)
$121 = 30.000 (Y-axis acceleration, mm/sec^2)
$122 = 30.000 (Z-axis acceleration, mm/sec^2)
$130 = 200.000 (X-axis maximum travel, millimeters)
$131 = 200.000 (Y-axis maximum travel, millimeters)
$132 = 200.000 (Z-axis maximum travel, millimeters)
ok
Easel:
Homing not in original location:
Messed up sign:
G-Code:
$0 = 10 (Step pulse time, microseconds)>> $$
ok
Easel:
Messed up sign:
