1 - 11 of 11 Posts
Discussion Starter #1
I am new to the site and totally green as a woodworker, but I want to learn. At age 71 I need patient simplicity whenever possible.
Premium Member
Welcome. You are not alone in starting late. Many of us didn't really get going untile we turned gray. I'm going to post a long piece here that is for someone getting started. It is the 17 plus things that I've leanred that really helped me get over the hump with starting. Don't worry about doing everything at once, but I think it's good to know more rather than less. Getting to where I am has taken a decade so. I hope it will save you some time, expense and trouble. Print it out and read it from time to time.
There are several items in the first segment that are worth considering right away. This has been published before, so those seasoned members might wish to skip this.
These are the 17+ things that really helped me get going with woodworking. Hope it helps you as much as they did me.
1) If you are using Firefox browser, get a free add on YouTube download helper app. Search for videos on all aspects of woodworking that interest you and collect them. I watch a video on the topic of whatever project, or phase of a project, on which I'm currently working. VERY helpful to see it done a few times before you try it yourself.
My downloader puts a download button under the video on YouTube. Click the button, name the file (I always label it according to the tool or job it works on. For example, anything to do with routing, I label as "Router", which clusters all the similar videos together in Windows Explorer. All my videos go into a single folder. I sometimes watch woodworking video while on planes, which triggers some interesting conversations.
2) There are hundreds of used books on woodworking on Amazon. Order some on basic tools and woodworking. You'll need to learn to tune up saws and other tools, and books are how I learned to do these things. It wasn't until I tuned up my saws that good results began to happen. My saws cut exactly 90 and 45, or any angle I need now. Two books I really love are Bill Hylton’s “Woodworking with the Router,” and “The Joint Book” by Terrie Noll. The Noll Book is a really concise and heavily illustrated reference with great hints for making every variety of joints. There are lots of good table saw guides.
3) I made some of my first projects with MDF or ordinary plywood before using more expensive material. Make the same project several times with improved skill, material and workmanship each time. Great learning method.
4) Consider making cabinets or stands for each of your power tools as first projects. My first cabinet was of MDF and my sander and all my sanding gear still sit on and in it. I can't tell you how much confidence I got from building space efficient shop stands and now, all the tools in my smallish shop are on casters and easily moved around for use and cleanup. Put doors on every cabinet to reduce wandering dust and to master making face frames and doors. BTW, if you add casters, use two non swivels on the back and two locking casters on the front--make sure the lock secures both the wheel rotation and the swivel so your carts don't skip around in use. My shop made stands also take up far less floor space than the spread-legged ones that came with many tools, which makes it far easier to move tools around in a compact shop--which is necessary to clean out the insidious sawdust.
5) Many of the woodworking supply stores in the US (and I imagine overseas) have demos on weekends. Attend and get to know the people you meet there. They can turn you on to sources of wood and you can get some nice help and begin a friendship or two. Don’t forget to talk with the employees as well. At our local Rockler, several of the employees are serious and experienced woodworkers and always eager to help. I’ve also found some of the big box stores employ a few very experienced wood workers, carpenters, electricians and plumbers. You just have to start a brief conversation, if they seem knowledgeable, ask them about what they did before they worked at the store, that will get the conversation flowing.
6) Among your first purchases should be some form of dust control. Many woods are proven carcinogens and can quickly damage your lungs. Dust collection information is on this site. I had a 4-inch, home made system installed to collect sawdust (see update below), but I also have and recommend a dust mask with a small fan that pulls in pressurized air that not only keeps dust out, but also keeps my glasses from fogging. Got mine at Rockler and I keep a couple of sets of rechargable AA batteries ready to use.
For cutting just a piece or two, I keep surgical style disposable masks handy. I also built a box with 20x20 filter inside and a fan that pulls air through to remove fine airborne dust over time. You can even tape a filter to the back of a fan in a pinch. Don't take your mask off right after cutting or cleaning up because there is always dust floating around for awhile. If you start coughing, it means you need to pay very close attention to dust control and wearing a mask. It takes months to recover from a bout of working unprotected with MDF (Medium Density Fiberboard) without a mask.
Update: After spending a LOT of money trying to make my own dust collection system work, I bought a 4 inch/100mm, 2hp unit from Harbor Freight for about $200. It collects the sawdust in a plastic bag which is easier and far less messy to dispose of. The HF unit was on sale and goes on sale from time to time. I would have been money ahead to have bought it in the first place. There are many dust collection machines out there and I wouldn’t go the home made route again.
Chop and miter saws are usually the worst sawdust scattering offender in the shop. My solution was to use a clear plastic shower curtain that wraps around the saw and catches most of the sawdust that drops down into a collection box. Don’t force your cut on this kind of saw since that seems to make the scatter even worse. Pull the blade across the workpiece toward you for a shallow cut, then deepen the cut pushing the blade away. This channels more sawdust backwards into your collection system.
I also use my dust collection system to clean up the floor. It has one 4 inch flex hose that moves from tool to tool. My router fence has a 2.5 inch port behind the bit, on the fence. There is also a 4 inch port on the box that contains the router under the table. You can find an adapter that has a Y shape, one arm attaches to the 4 inch collector hose, the other connector goes to the fence port. It helps a lot. The problem with sawdust on the router table is that it can lift the workpiece up slightly so your cuts will be off. You must sweep this sawdust away frequently, so keep a wide brush handy.
7) Take your sweet time with projects, there's no rush and it is easy to have a project nearly complete, then make a careless, quick cut or other error that ruins all your good work. In most cases, it is best to fit pieces by putting them in place and marking rather than just measuring and cutting. Cut a bit over and shave the piece down (or use a good block plane) for an exact fit. A good block plane, nice and sharp, is a basic tool you'll use more often than you’d imagine.
8) Buy the very best table saw you can manage. It will quickly become the most used tool in your shop. A little debt could move you up a notch and help you produce better results and cut thicker wood. Get the best tools you can afford and set them up as precisely as you can, you’ll find instructions in your used book collection or on YouTube. Read the reviews and ask questions on the forum before you choose. To me, it is worth it to use credit if necessary to move up the quality scale for the table saw.
There are models called hybrid saws that have the mechanical works attached to the cabinet rather than the top, which is good. I recently replaced my old contractor saw with a Laguna Fusion saw. My shop is not wired for 220, so I was happy with the 110volt, 1 3/4 hp motor. Many forum members have been very happy with less expensive models, Grizzly for example, but I prefer the Laguna for its amazingly flat table and extensions and its fit and finish (and reasonable price). Learn to set up and tune up your saws and tools (books and videos show you how) because you can’t make anything great if your tools are even slightly off. Many people prefer the Saw Stop because it all but eliminates the risk of cutting off a digit, but you’ll pay about twice the price of otherwise equal saws.
Until you get a good table saw, you can get fair results using a circular saw and a straight edge. A home made straight edge is made by attaching a 1x straight edged board to a piece of hard particle type board (Masonite in the US). Run the saw along the 1x to cut off the excess and to form a perfectly straight edge. This will also reduce chipout or rough edges. The finished jig will be 250-300 mm wide (10-12 inches), by about 5 ft. long (150 cm).
The best safety device is paying very close attention to what you’re doing with a saw, but a close second on the table saw is a MicroJig Gripper, which lets you control wood on the saw while keeping your fingers safely away from the blade. There is a fancy and a simpler model, either of which is good.
Band saw add on: I had a conventional Delta band saw, and never used it much. Recently bought a Laguna 14/Twelve band saw primarily for resawing. It is a beauty and was on sale to boot. I have not really used it much so far nearly as much as a smaller 10 inch Rikon I use for minor cutoffs or curves. If you're making furniture with curves, a good, 14 inch or larger band saw is a must.
9) If you can, get an electrician to add a 220 outlet or two to your shop (USA only). If you set up in the garage, you may be able to use the electrical outlet for the dryer. There are many tools that require 220 volts to work best, and many used 220 v tools are available at really good prices--if you feel comfortable buying used. Another tool source is to visit estate sales. Every once in awhile, you find tools no one else in the family desires or knows the value of, so you can get them cheap.
If you don't have a router yet, I have come to like the Triton TRA001, which is perfect for table use, particularly since you can adjust height quite precisely from the above the table with its built in lift. That feature really saves my knees. However, it is just too heavy for this old guy to control freehand. I really like the Bosch 1617 EVSPK for hand held use. There is a newer model that has a light and switch on the handle that costs more. Both come in a kit with fixed and plunge base. Bosch has many accessories available that are very well made. Others like different brands, but Mike recently checked in on the topic and compared PorterCable plus other brands and I thought the Bosch came out ahead. I prefer the raising and lowering mechanism on the Bosch with its precise micro adjustment knob. The Bosch fixed base can be used as a lift in a table. The books on routers and other topics are really useful for understanding some of the arcane woodworking terms associated with this must have tool..
10) When it comes to router bits, try to stick to the half inch (12mm) shafts with carbide cutting tips. These are astonishingly sharp. Bosch and Freud are easily available at HD and Lowes, but there are lots of other excellent brands including the well liked Whiteside and Sommerfield bits. Be careful of those ultra sharp tips, which are fragile. I'd suggest storing them in one of those foam lined cases you can get pretty cheap from Harbor Freight, loosely packed so they don't click together. A few of the cheap bits don’t have carbide tips. Spiral bits are sometimes used to cut grooves. Carbide spiral bits are both expensive and fragile and it takes very little abuse to ruin them. Many use high speed steel bits for that purpose.
I buy bits as I need them and don't much care for kits. However, someone recently suggested getting a kit to start out with, then gradually replacing only the bits you actually use with top grade bits. This makes some sense to me, but stick to the half inch shafts if you can manage it--most kits I’ve seen have 1/4 inch shafts. I would avoid huge sets with odd bits you are unlikely ever to use. A few standard bits most of us have are the round over bits. You can get them in different sizes, but mostly you’re likely to use the quarter, half and ¾ sizes. Another bit that is very useful for cabinetry is the half inch rabbiting bit with a bearing. Some come with a changable bearing that allows you to change the depth of the rabbit. Doing fancier stuff makes those cash register numbers spin because door bit sets, for example, are pricey!
One more thing about using bits, don’t try to take off too much wood in one pass. Make several passes taking a little more wood with each pass. Pay attention to the grain of the wood (that is covered in most books on routing) with a final pass just shaving and making for a very smooth finish. My personal rule is to cut no more than 1/8 th of an inch per pass. The larger the bit, the slower you should set the speed control.
11) The most useful item I own for my saws is a Wixey digital angle gauge, which allows me to set up all my saws to exact angles (eg: 90 degrees to the table). It wasn't until I started being meticulous about this that my projects started working out right. These are about $30 on Amazon.
I have a Bosch 10 inch compound sliding miter saw that I also love, but use it mainly for cross cutting long pieces, but its ability to cut at precise angles is wonderful.
12) Pocket Hole jig and construction. Although there are many ways to make cabinets and face frames, I have found that pocket hole screws have really made making them easier. Just remember, coarse threads for soft woods, fine thread for hard woods, and I find the square head easier to drive correctly than the Phillips type. My jig is mounted on a chunk of plywood that I can clamp down. The thing makes a lot of sawdust so dust collection is a good idea. I also find that with careful, exact 90 degree end cuts to the wood, the pocket hole approach produces absolutely square cabinets and face frames. You’ll want a couple of face clamps and a Kreg right angle clamp if you use pocket hole joinery on cases. There are many helpful videos on this jig and it is not very expensive as tools go.
13) Make a table saw sled (lots of YouTube videos on how to) for perfect 90 degree cuts on your table saw. I had a little more money than time, so I bought the sled Rockler makes that has a swinging fence and a very precise angle scale. I love that thing and set up a special shelf right next to my table saw to store it and keep it flat. Cross cuts on the sled are wonderfully exact and it prevents most tear out, the ragged or splintered area at the end of a cut. The sled is also a much safer way to cut short pieces as well. You set the sled to a precise 90 or 45 angle using a drafting square.
Most saws come with a miter gauge, but I prefer one of the precision gauges. I have an Osborne gauge I really like, but many here like Incra’s gauge. Precision is important with gauges.
You will read a LOT about jigs here and in your books and videos. Jigs, accurate T squares, a good straightedge are all incredibly useful for producing good work. The more I venture into really good hard wood construction, the more I appreciate how jigs produce accurate results without wasting expensive wood through mis-cuts.
14) I had a lot of problems with tear out at first, but most of that stopped when I started using a sacrificial backup block to push the last bit of a piece through the router or saw. I often use square pieces of MDF (medium density fiberboard) because it is cheap and stays flat. When it gets torn up, I just cut off a chunk and use what’s left. Really helps! You can do the same with any piece by putting a backer board behind where the cut goes--you cut through the piece first, the backer last. You may also want to use feather boards to hold boards in correct alignment to the fence and blade or bit.
Zero Clearance Inserts for the table saw: On the table saw, buy or make blank inserts to make zero clearance inserts (see YouTube for how to do it), this really helps make great, tear-out free cuts. I also found that I wanted to push that last quarter inch through the bit too fast, now I feed at a steady pace all through the cut.
15) Clamps: The joke is you can never have too many clamps. The ones I use most are about $3 each at Harbor Freight, about 9 inch F clamps (they look like an F). I have 18 of them. The same source has longer versions up to 24 inches and I keep 4 to 6 of the 18 and 24 inch models. I have four sets of two of 24 to 60 inch (Jet) parallel clamps for making really square cabinets and other items where holding things square for glue up is important. The better the quality of bar clamps, the thicker and stronger the bar will be. I’ve all but given up on plastic clamps, but have a few that look like scissors for lightly holding things together or down. Depending on what you’re making, a few wooden hand screw clamps could be useful, including holding small parts for safer routing. I recently added a couple of special steel C clamps that have a 12 inch open throat. Very handy item!
16) Hand planes and hand tools: Learning to use these is something of an art, as is proper sharpening and setting of their blades. There are lots of woodworkers who really love working with hand tools, most will suggest you buy used and clean and tune them up--which is actually quite fun. I prefer just to buy new and really like the Wood River V3 brand for its quality and acceptable price.
Chisels are important particularly if you are making furniture. Sharpening chisels is a basic skill involving many ultra fine grits of sandpaper, ultra flat surfaces, maybe diamond grit sharpening stones—arcane stuff, but anything less than a razor sharp chisel is pretty useless. Don’t scrimp on chisels, cheap ones get dull fast. Look up sharpening methods on YouTube, it takes patience but not much money to work sharp. I recently bought a diamond sharpening device with diamond dust imbedded in a nickel steel plate. It has small cut out ovals so the metal grit doesn't clog the diamond surface. Use these sparingly and use one of the specialty diamond sharpening lubricants with it. I use this for quick sharpening touch ups, just 4-5 strokes will do. It’s a little easier to use than the sand paper method, which I save for major sharpening tasks. The most important thing is to flatten the back of the first inch or two of the chisel. Unless that is flat, you can’t sharpen a chisel or plane blade (iron) accurately.
The one plane every shop should have is a small block plane. These have so many uses that’s it is hard to list them all, but they are really great for trimming up ends of workpieces, quickly rounding over edges without having to set up a router, fine fitting the length of a board. New ones can be had in decent quality for about $100 bucks and up. All planes require being tuned up before they are any good. You can look this process up on YouTube. Cheap block planes are passable if you really work them over first, but most won’t hold an edge very well and some are not milled accurately and will never cut right.
17) If you have a dedicated shop space, take the time and trouble to insulate it. You will enjoy working in it much more if you're not roasting or freezing. I installed a middle sized window AC unit through a shop shed wall for relief from our desert summer and it is now even more of a pleasure to be out there. Insulation also holds in heat during winter. A couple of heaters bring the temp up, but just one keeps it comfortable after that. Cold fingers are clumsy, not good around spinning blades!
Finally, Stick suggests that you use the Forum’s archives when you have questions. There is a wealth of answers to any questions you might have. He also cautions about using one word search terms, which can return massive amounts of information. Here’s the link: https://archive.org/
Woodworking is not necessarily a cheap hobby. Wood can be costly, so are decent tools, And there's hardware, stuff for jigs, dust collection and on and on as you get going. My good wood supplier is 60 miles away, so I often work in decent local pine and plywood with as many layers as I can find. I found some decent plywood at HD. Before long you will hear how superior Baltic Birch is to the best of HD ply, but you have to ferret out a decent source. Chinese made birch ply is generally no match for the real stuff, which, when you cut it shows no voids inside. To me the 60 miles is a small price to pay to work with the good ply.
This has run pretty long, but I think the information is helpful for someone new to the hobby. The suggestions represent a LOT of trial and error. And yes, you can spend a lot getting set up, but most of us built up our shop and tools over time, nearly a decade for me. Beside that, my wife likes me being around, but busy out in the shop. Revised 11/27/16
Welcome to the forum Erm. We have all the patience in the world as many of us are retired. If you need a question answered just ask but be aware that there is a good chance you'll get suggestions for more than one way to do some things. It will be up to you to decide which one will work best for you. In the meantime when you get a chance fill out your profile so that when you do ask a question we can see what you have to work with as that will influence some of the suggestions. A name or nickname would be nice too.
Reactions: Albe
Super Moderator
John
:) Hello and welcome the router forum.
Reactions: Albe
Ross
Welcome to the forum.
Reactions: Albe
Welcome to the forum. DesertRatTom has a truckload of good advice. Good luck with your projects.
G'day, and welcome to the forum..
1 - 11 of 11 Posts
