1 - 6 of 6 Posts
· Registered
Hi
I hope this helps someone unless it has already been posted. I own a Makita router and it has depth stops but no graduated fine adjustment for depth. I have found a great way to get around this.
If I want to creep down on a finished size down to a depth. I come down in 1mm increments using drill bits in between the stop rod and the stop. eg start at 7mm for example then come down to a 6mm drill and so on.
Another way to finely adjust depths is by using feeler gauges. I can successfully creep down to a depth this way. eg if I want to drop by 0.2mm, at depth, release stop rod and place a 0.2mm feeler gauge in between rod and stop base and reclamp. This leaves a 0.2mm gap and you simply bring down router to new stop. If you are 0.2mm too deep and want to bring up the depth, bring router down on top of the feeler gauge, take feeler out then reclamp the stop down to new depth.
· Registered
Thanks for the tips! Always nice to see solutions that can be found with a little out-of-the-box thinking. I've used drill bits to set up exact depth cuts many times in the past. Never had feeler gauges until I bought a 3d printer that needed setting up. Usually when depth is critical I'm using a trim router to cut pockets for hinges or other hardware. The hardware itself becomes the spacer used to set up the router.
4D
· Official Greeter
Some good tips there...
We all have a set of drills around somewhere...
· Official Greeter
Welcome to the forum, @EW Custom Woodworks .
Glad you find the forum still relevant and useful..
1 - 6 of 6 Posts
