Guess I’ll go back to the good old fashion using straight edge routing.
No matter how I set up the router in-feed and out-feed; I get a ½ inch snipe at the end.
I don’t get it. I have enough pressure to keep the out feed stock pressed against the out feed sub-fence so theoretically this shouldn’t happen. Also there’s no downward/trail pressure over the bit. I suspect that the out-feed might be a bit low but I’ve set and reset.
Any ideas?
Thanks.
Any ideas?
Thanks.
