A general questions regarding how square a square is
normally a squares squareness is given something like .005 or .006 (when you're buying it)
which I have always taken as the deviation from square over the length of the blade
Hence if you have two squares, one with a 4 inch beam & one with an 8 inch beam and they both have a number supplied by the manufacturer as ".005" then the 8 inch one should be more accurate or closer to square when measuring a 6 inch board.
now the question
Somewhere-- I remember reading that the number (.005) is actually measuring the PARALLELISM of the beams edges not the degree of deviation from 90 degrees. I know I read it on a manufactures web site while searching for an affordable square
Anyone with expertise in this care to weigh in & enlighten me??
thks
smitty
now the question
thks
smitty
