Not Worth a Plug Nickel......
2484 Views 14 Replies 10 Participants Last post by  honesttjohn
Had a request for a real wooden nickel. This called for a thing called "two sided machining." Never did it - don't have a clue. I tried my idea of cutting one side, flipping the piece over, and cutting the other. Should work if the x and y are maintained, right? With the lip of the coin everything had to be perfect. It wasn't. After a reach out to Beltramidave and MEBCWD I attempted to do it by the book, using the dowel method. It worked!! I used the nickel bank file and shrunk it down. It's just a 11 x 8 piece of cut off baltic birch 3/4" panel. Finished coin measures about 6 1/4 inches in diameter.
1 - 15 of 15 Posts
That's a nifty project.
Nicely done, John! I've done several two-sided projects and yes, the dowels really help for alignment.
David
More dowels the better! I did 2 and had a little slip because they weren't really 1/4" diameter, tried again with 4 dowels and worked great
Reactions: 2
what's the dowel method???
Reactions: 3
Very nice John . I love neat projects like that . I seen one before where it was much larger and made into a piggy bank . It was painted ,but I prefer the bare wood look
John or anyone,please correct me if I'm wrong,but shouldn't the "plugged"nickel have a bullet hole in it.I'm not being a smart-ass here ,I always thought that's what it had to have otherwise it's not worthless. James jj777746
Stick,
It's a means of making sure that your project is machined exactly where it needs to be on both sides by boring index holes into the piece and the spoilboard.
Reactions: 4
When you design your project you add holes that will be drilled in the first side of the project blank sized for a snug fit for some dowels. As Doug said the more the better. Three work pretty good. These holes need to be precisely located in relation to the overall center of the project. Then another set of holes is set up by locating them by mirroring around the job center so they are a flipped version of the ones for the project blank.
This second set of holes will be drilled into the spoil board and when the blank is flipped over to cut the backside the holes will line up and you add the dowels to register the blank to the spoil board. This centers the front and back cuts so that everything matches up.
After you have done this a few times you realize how easy it is.
The important thing to remember is to make sure the first side is machined with the registration holes drill in the project blank before removing it from the spoil board. At that point, you can drill the registration holes in the spoil board and locate the blank using the dowels, then cut the backside OR you can actually move to any point on the spoil board, zero your X-axis and Y-axis and drill the spoil board registration holes, then mount you project blank using the dowels for registration and cut the backside. With that in mind, you can cut the first side of the blank or several blanks, shut down for lunch or overnight and still be able to register the front to the back of your project. The important things to remember, you need to locate the registration holes correctly in your design file and make sure you drill the registration holes in the first side of your project blanks before you remove them for the spoil board.
ahh..
orientation pins...
thanks..
I used 3 and it worked pretty good
Drilled 3 holes on the top side and put dowels in them. Then mirrored the hole pattern on a spoilboard. The dowels will fit in those holes and (hopefully) you can cut the backside accurately.
That's what counts HJ, it worked and looks like a pretty cool method.
On a curious note, you seem to be bizzie on the spoil board.
What else ya cuttin? huh.. huh... come on spill it.
Just he usual, Ronnie. A bunch of Polish Eagles, text signs, and repeats of things already shown here at one time or another. Xmas kicked off - got 6 custom orders from Etsy yesterday. Been using up inventory at the store display. Got to think of something new or different this winter to add and cut like
the devil this winter to get ready for next year. Plus.....it is hunting season.
Reactions: 3
Fantastic results but I'm guessing, like the government, it cost more to make than the face value (think penny) :) Is that a counterfeit plug nickel?
Shhhhh
1 - 15 of 15 Posts
