Hi Chris
1st.let me say "the deeper the bit the tighter the fit" Bob and Rick
When using the Oak-Park Mitre setup put the dovetail in and use the 3/8" brass bar on top of the black jig to set the height, 3/8" is the norm, but you can use 5/16" if you want BUT both parts for the dovetail joint must be set the same.
Use the jig to cut both parts of the dovetails.
That's to say once it's set don't move it up or down.
To repair what you now have, I would put in a 3/4" dado slot and then cut some stock to put in the dado, a plug so to speak, let it dry and then flush trim the leg with the flush trim router bit and then start over.
If you have a 3/4" or 1" dovetail bit, that would best for the plug and would give it a nice touch (walnut/cherry/ ??, but it takes more work than the standard dado slot.
But this is just my 2 cents.
Bj
Bj
