I went to the woodworking show this past weekend and picked up a 24 x 8 x 3/8 piece of HDPE. Not sure what I was going to do with it... I took it yesterday, cut a strip 3/4 inch wide, used a 1/4 straight bit and cut a slot in the middle of the sheet, about 4" shy of each end, just under 3/8 wide. Cut the strip to fit in the slot......
Now I have a box joint jig. I installed a bit, clamped the jig to my table and ran a test.......
Came out very nice... a bit shy on the depth so the ends would be completely flush... but all that is needed there is too set the bit a "bit" higher.
Ok.... I'm cheap and I duplicate other peoples ideas.....
Is that "WRONG"? Or should I feel bad... only for a moment?
Oh yea... the piece of HDPE was $5.00
