...how do I follow a line?
What I am trying to do right now is joint the ramp with the top step at a 43/an 53 angle. Is that right? I am trying to make the oppisite of a dovetail:sad:
Lainie
This should help with the nomenclature, so you know what we are talking about (common understanding):
I understand that you are really creating a ramp with one stair step... Draw it out on both sides of the stair stringers. Mark the side of the cut that will be cut away with X'es, occasionally on that side, so you know what will be your waste side.
If all you have is a jig-saw or handsaw, then clamp, tack nail or screw some scraps along the off-side of your cut-line (the bottom side when you are cutting), on the same side of the cut that will be kept. That way, as you cut along the line that you see on your top or visual side, you can guide the saw along that visual line -and- the scrap will act as a guide on the opposite of the cut, to keep the blade from wandering and cutting too much off the offside.
If it does wander to the outside (into the waste side), that is okay, as you can turn over your stringer and trim off more waste along that line... You can always trim off
more. But it is harder to add a tad "more" to wood.
That just is a beginners basic tool way on how to cut a stiaight/perpendicualr line for someone just starting out with woodworking skills.
If you had a longer blade. such as with a hand saw, you could screw scrap and both sides of your workpiece and on both sides of the cut, so that the saw would cut between the scrap, on both sides, and be guided in a way that there would be no change or wander with the blade. That would end up like a hand-powered miter saw...
