This clock is a motor driven remontoir clock with a balance pendulum. It was designed by Clayton Boyer. I purchased his plan for the clock last Christmas. He was able to provide a couple of emails that pushed me the right direction, a big help. At this point it doesn't keep very good time but I enjoy looking and listening to it. For those who like to jump ahead you can see a short YouTube video here:
The frame, dial ring, and pendulum are cherry. Those darker pieces are some Brazilian hardwood from a chair I'm re purposing. The gears etc are Baltic birch PW.
Thanks for looking. Stay safe.
Here are some of the plans. I made a copy to start because most are cut and pasted onto the stock.
Layout out drawings, taping them into groups and cutting the frame.
Cutting gears.
Balancing gears
Drilled an number of arbor holes. This was the first, you can see I'm off the mark. I changed to making a starter with an awl before attempting to drill and that helped.
For part of the pendulum and the dial ring sections had to be cut and glued together.
This cannon or pinion gear was tough. It's 1/2" stock and about 1" diameter. The arbor drilling need to be different sizes on each side and it had this little locking screw too.
Horizontal boring.
This is the part that holds the motor and battery.
Mostly laid out before assembly.
Cutting gears.
Balancing gears
Horizontal boring.
