1 - 7 of 7 Posts
Premium Member
Discussion Starter #1
Any computer guru's here? I know we have a couple among us...
My laptop, running WinXP Media center, keeps returning an "unknown" error when I check my email. I know it's a setting or program on the laptop because my desktop will check and retrieve email with no errors.
Any idea where or what?
Both computers are set up identical... with the exception being media center on the laptop, and xp pro on the desktop. Both running AVG antivirus, Zonealarm firewall, Outlook express 6, and Winblows firewall turned off.
It's driving me nuts!!
Brian
Hi BrianS
The easy way to fix this error is to use the Restore Wizard (a windows built in program) , back to a point where you don't have the error poping up...:)
Then once you get the error off down load the free program below(ERUNT),install it and run it, it's a quick way to get things back .
ERUNT The Emergency Recovery Utility NT
AND
NTREGOPT NT Registry Optimizer
ERUNT=Registry Backup and Restore for Windows NT/2000/2003/XP
http://www.larshederer.homepage.t-online.de/erunt/
Read this text page for more info
http://www.larshederer.homepage.t-online.de/erunt/erunt.txt
ERUNT - The Emergency Recovery Utility NT
v1.1h, 03/06/2005, Freeware
Written by Lars Hederer
e-mail: [email protected]
Look for the latest version here:
To find out what's new in this version, please see the "Version
history" section later in this file.
Plus run CCleaner
CCleaner 1.22.142
http://www.majorgeeks.com/download.php?det=4191
CCleaner (Crap Cleaner) is a freeware system optimisation tool. That removes unused and temporary files from your system - allowing it to run faster, more efficiently and giving you more hard disk space. The best part is that it's fast! (normally taking less that a second to run) and Free.
NOTE *** about CCleaner
Take care with this program,computers are not smart they only do what you ask them to do no more no less.
Read,read,read and then uncheck the item(s) that you are not sure about.
It will remove what you have checked...
Have a good one.
Introduction To ERUNT
With the invention of Windows 95 Microsoft made the wise decision to
organize all computer- and application-specific data which was spread
over countless INI files before in a centralized Windows database,
called the system "registry". The registry is one of the most
important parts in every Windows system today, without which the OS
would not even boot. And since the registry is quite sensitive to
corruption, it is very advisable to backup its according files from
time to time.
In MS-DOS based Windows versions (95, 98, Me) the registry consists of
the files SYSTEM.DAT and USER.DAT (and CLASSES.DAT in Windows Me). To
backup these files, one can easily go to the Windows folder in
Explorer and copy the files to a safe location, for example another
folder on the hard disk. Microsoft even supplies a utility called ERU
which can be used to backup these and a few other critical system
files to a safe location.
Also, Windows 9x/Me automatically create backups of the registry at
startup, with Windows 95 always backing up the registry from the
previous Windows session, and Windows 98/Me maintaining up to five
registry copies from the last five days where Windows was running.
Unfortunately, this is not the case with Windows versions based on the
NT kernel. In Windows NT and 2000, the registry is never backed up
automatically, and in XP it is backed up only as part of the bloated
and resource hogging System Restore program which cannot even be used
for a "restore" should a corrupted registry prevent Windows from
booting. It has also become impossible to copy the necessary files,
now called "hives" and usually named DEFAULT, SAM, SECURITY, SOFTWARE,
SYSTEM in the SYSTEM32\CONFIG folder, to another location because they
are all in use by the OS. And though the registry in an NT-based
Windows is less likely to become corrupted than in other versions, it
can still happen, and for these cases NT is simply missing an option
for easy registry backup and restore as there is in Windows 9x/Me, to
get the system up and running again in no time.
In 2001, as Windows XP began to come pre-installed on many new home
user PCs and was likely to become the new Windows standard over the
next years, I decided to write a program which offers the ease-of-use
of Windows 9x/Me ERU by Microsoft (hence the name ERUNT) to backup the
registry, as well as providing an auto-backup capability, for example
at Windows startup.
Or, before installing a new program for testing purposes one could
save the registry with ERUNT, install and test the program, uninstall
it and restore the registry to be 100% sure that no debris is left.
Note: The "Export registry" function in Regedit is USELESS (!) for
making a complete backup of the registry. Neither does it export the
whole registry (for example, no information from the "SECURITY" hive
is saved), nor can the exported file be used later to replace the
current registry with the old one. Instead, if you re-import the file,
it is merged with the current registry without deleting anything that
has been added since the export, leaving you with an absolute mess of
old and new entries.
Features
- Backup the Windows NT/2000/2003/XP registry to a folder of your
choice
- System and current user registries selectable
- Command line switches for automated registry backup and restoration
- Restore the registry in Windows 9x/Me/NT/2000/2003/XP and MS-DOS
(all-in-one restore program) or the Windows Recovery Console
- Included in this package:
NTREGOPT program for optimizing the registry
- All programs in this package are completely localizable
(translate them into your language), German version included
Supported operating systems
- Windows NT 3.51
- Windows NT 4.0
- Windows 2000
- Windows 2003
- Windows XP
- most likely, all future Windows versions based on the NT kernel
Additionally supported by the ERDNT restore program:
- MS-DOS
- Windows 95
- Windows 98
- Windows Me
Installation
Use the Setup program to install ERUNT on your computer.
Or, if you downloaded the zipped version: Unzip all files into a
folder of your choice, and if you want, create shortcuts on your
desktop to the ERUNT.EXE and NTREGOPT.EXE files.
Uninstallation
Use "Add/Remove Programs" in Windows' control panel to remove ERUNT
from your computer.
Or, if you downloaded the zipped version: Delete the ERUNT folder,
delete the appropriate desktop icons.
(You may also want to delete all restore folders you have previously
created with the program.)
Backing up the registry with ERUNT
Note: To ensure proper operation of ERUNT, you should be logged in as
a system administrator.
Start ERUNT, confirm the Welcome message.
Type in the name of a restore folder where the backed up registry
files should be saved, or click "..." to browse your computer's drives
and select a folder. You can also simply leave the default, which is a
folder named ERDNT inside your Windows folder, the advantage being
that you have access to this folder from the Windows Recovery Console
in case Windows does not boot anymore.
Note that in the folder edit field, ERUNT by default appends a folder
named the current date to the restore folder, which allows you to keep
as many registry backups as you wish in the same restore folder,
separated into the different creation dates. This feature, as well as
the appearance of the date string, can be configured via the ERUNT.INI
file, described later in this document. If you want the registry backup
to be created directly in the folder you select, you can also simply
remove the date from the folder edit field before clicking "OK".
Next, select the backup options:
- System registry: The current system registry, usually consisting of
the files DEFAULT, SAM, SECURITY, SOFTWARE, and SYSTEM.
- Current user registy: The registry files for the currently logged-on
user, usually NTUSER.DAT and USRCLASS.DAT.
- Other open user registries: Sometimes Windows has a few other user
registries in memory. Examples for this are "generic" registries,
e.g. for user "EVERYONE", or registries of other users if you use
Fast Task Switching in Windows XP. Check this option to backup all
these additional user registries (if found) as well.
Click "OK" and wait until the backup process is complete. (Note that
depending on your system configuration this may take some time, and
that the first bar is NOT a progress bar, just an indicator that the
program is still running.) The ERDNT program for later restoration of
the registry is automatically copied to the restore folder.
(Technical information: ERUNT saves only registry files which are in
use by the system. It obtains information about these files from
registry key HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\
hivelist. Registry hives not listed there, for example those
of other users of the computer, cannot be saved by ERUNT.)
ERUNT command line switches
ERUNT supports command line switches with which you can perform an
automated registry backup, without user interaction. The syntax for
the ERUNT command line is as follows:
ERUNT DestinationFolder [sysreg] [curuser] [otherusers]
[/noconfirmdelete] [/noprogresswindow]
DestinationFolder is required for command line operation of ERUNT,
all other switches are optional.
If you specify a destination folder on the command line, ERUNT
automatically runs in "silent" mode and with default backup options
(system and current user registry). No user interaction is required,
EXCEPT the confirmation of the restore folder deletion if it exists,
or any error messages. The confirmation question can be suppressed
by using /noconfirmdelete (see below).
Description of the command line switches:
DestinationFolder
The name of the folder where the registry backup should be saved.
Example: C:\WINDOWS\ERDNT
You can use the strings #Date# and #Time# anywhere in the folder
name to have ERUNT insert the current date/time at that position.
Example: C:\WINDOWS\ERDNT\#Date#
Windows' %SystemRoot% environment variable can be used on the
command line as a substitute for the name of the Windows folder.
Example: %SystemRoot%\ERDNT\#Date#
sysreg
Backup the system registry
curuser
Backup the current user registry
otherusers
Backup other open user registries
(Note: If none of the three above options is given on the command
line, ERUNT automatically uses the default backup options, system
and current user registry.)
/noconfirmdelete
Automatically deletes the contents of the destination folder if it
exists, without asking the user. BE CAREFUL and only use this option
if you are sure that the contents of that folder may really be
deleted!
/noprogresswindow
Hides the progress window during backup.
So, to backup the system registry to folder C:\ERDNT each day of the
week using subfolders with the name of the current day you could use
the integrated scheduler in Windows to schedule seven different ERUNT
calls for each day:
For Monday you would use the command line
C:\ERUNT\ERUNT.EXE C:\ERDNT\Monday sysreg /noconfirmdelete
For Tuesday you would use the command line
C:\ERUNT\ERUNT.EXE C:\ERDNT\Tuesday sysreg /noconfirmdelete
... well, you get the idea.
Or, to have ERUNT automatically backup the registry on each Windows
startup to a folder named "ERDNT" inside the Windows folder, including
a folder named the current date, you could place a shortcut like the
following in your Start Menu/Programs/Startup folder:
C:\ERUNT\ERUNT.EXE %SystemRoot%\ERDNT\#Date# /noconfirmdelete
If you want old restore folders created this way to be deleted
automatically from time to time, you can use AUTOBACK.EXE instead of
ERUNT.EXE. The AUTOBACK tool is described later in this document.
Also, ERUNT Setup offers the choice to add an AutoBackup shortcut to
the Startup folder automatically during the installation process.
The ERUNT.INI file
You can configure various ERUNT settings with this file, for example
change the default destination folder displayed in ERUNT's folder edit
field, or disable automatic appendation of the current date there.
Use Notepad to create a file named ERUNT.INI in your ERUNT folder, and
add the following line:
[ERUNT]
Below this line, enter one or more of the following configuration
options:
DefaultDestinationFolder
The name of the default folder displayed in ERUNT's folder edit
field. You can use the Windows environment variable %SystemRoot% as
Default: %SystemRoot%\ERDNT
Example:
DefaultDestinationFolder=C:\ERDNT
AppendDateToFolderEditField
Enable or disable automatic appendation of the current date to
ERUNT's folder edit field.
0=disable, 1=enable, default: 1
Example:
AppendDateToFolderEditField=0
AppendTimeToFolderEditField
Enable or disable automatic appendation of the current time to
ERUNT's folder edit field. This function can only be enabled in
conjunction with AppendDateToFolderEditField also set to 1.
0=disable, 1=enable, default: 0
Example:
AppendTimeToFolderEditField=1
DateFormat
DateSeparator
These settings configure the appearance of the date string in
ERUNT's folder edit field, or when #Date# is used on the command
line. By default, ERUNT uses Windows' regional settings for the
short date format. Note that only "." and "-" are allowed as date
separators.
Example:
DateFormat=mm/dd/yyyy
DateSeparator=-
TimeFormat
TimeSeparator
These settings configure the appearance of the time string in
ERUNT's folder edit field, or when #Time# is used on the command
short time format. Note that only "." and "-" are allowed as time
separators.
Example:
TimeFormat=hh:mm:ss
TimeSeparator=.
DisableFastBackup
On supported operating systems (including Windows XP and Server
2003) ERUNT by default uses a very fast backup algorithm. If you
experience any problems during registry backup, you can try to
disable this function and revert back to the conventional (but slow)
method. This setting has no effect on unsupported operating systems,
where the conventional algorithm is always used.
0=fast method, 1=conventional method, default: 0
Example:
DisableFastBackup=1
The AUTOBACK.EXE tool
The command line tool AUTOBACK.EXE uses the same syntax as ERUNT but
performs the additional task of deleting old restore folders after the
new backup has been created.
For this to work properly, the name of the last folder in the command
line option DestinationFolder must begin with the current date, or the
#Date# string, respectively. If this is the case AUTOBACK
automatically searches the parent folder of the newly created backup
for folder names of the same date format and deletes all folders
except from the last 30 days where backups have been created.
The number of restore folders to keep can be changed using the /days:n
command line switch, e.g. /days:7 would only keep the folders from the
last 7 backup days.
By default AUTOBACK does not create a new backup if one already exists
for the current day. Use the /alwayscreate switch to change this
behavior and have the program always create a new backup.
AUTOBACK is dependent on ERUNT and therefore needs to be executed from
the same folder. It uses the same settings for the date format as
ERUNT does, so if you specified a new format in ERUNT.INI it will also
be used automatically by AUTOBACK.
Restoring the registry with ERDNT
Situation: Windows is running normally.
To restore a previous registry backup, open Windows Explorer, navigate
to the folder where you saved the backup to, and double-click the
ERDNT.EXE file to start the restoration program. (Each restore folder
has its own copy of ERDNT.EXE in it.) Select which registry components
to restore, then click "OK" to start restoration. When the process is
complete, click "OK" to restart the computer and activate the restored
registry.
Note: If you experience any problems restoring the registry, please
read "ERDNT technical information" later in this document to learn
what ERDNT is actually doing during the process, or simply read on
through the following emergency scenarios for other ways of restoring
the registry.
What to do if Windows does not boot anymore?
If Windows refuses to boot normally it can be for a variety of
reasons, not the least of which is that the registry is damaged, or
you installed a program or driver which is somewhat incompatible with
the system or buggy, in which case restoring a registry backup from a
point where everything was running smoothly should also help.
The first thing to try is to reboot and press the F8 key immediately
before the first Windows screen appears, then select the "Last Known
Good" option from the menu and see if Windows boots up with this
option. If it does, you're all set.
If it does not, reboot again with F8, and select the option "Safe
Mode". If Windows boots up in safe mode, you can restore a registry
backup just as you would in normal mode, as described above.
If safe mode also fails, read on...
Restoring the registry with ERDNT - Emergency Scenario I
Situation: Windows fails to boot up in normal and safe mode, but you
have a DOS boot disk or another (working) operating system installed
on your PC which is supported by the ERDNT restoration program, and
from which you have full access to the drive(s) containing the corrupt
Windows installation and the registry backup.
Boot up to the working OS, and open the folder containing the registry
backup you want to restore.
If the drive letters are different to as they were in the Windows
where you created the registry backup, you need to edit the ERDNT.INF
file now to reflect the new drive letters, before trying to restore
the registry backup. For example, if the drive with the corrupt
Windows installation is now available as D: instead of C:, then you
would change all C:\... references in the INF file to D:\... . Editing
the file can be done in Windows with the Notepad program, and in DOS
with the EDIT command.
Now run the ERDNT.EXE file to start the restoration program. Select
which registry components to restore (just the system registry will do
in most cases), then start restoration. When the process is complete,
reboot the computer and check if the other Windows installation is
repaired now.
Restoring the registry with ERDNT - Emergency Scenario II
Situation: Windows fails to boot up in normal and safe mode, and you
have no other working operating system installed on your PC.
The following two rescue methods require that your PC is configured so
that it can boot from CD. See your BIOS documentation for more
information.
1. Bart's PE Builder
Use another computer with Internet access and CD burning capabilities
to download this free program from the Internet (do a Google search
for it), which will create a bootable Windows CD with full access to
all drives (including NTFS). Boot from this CD, open the File
Management Utility and follow the directions in "Emergency Scenario I"
to run ERDNT and restore the registry.
2. The Windows Recovery Console (Windows 2000 and higher)
Note that you can use this method only if you saved the registry
backup inside the Windows folder, and that using this procedure only
the system registry is restored. This should however get you back into
Windows, from where you can run the ERDNT program to restore user
registries, if necessary.
- Boot your system from the Windows 2000/2003/XP CD-ROM.
- At the welcome screen, press "R" (Windows 2000: "R" then "C").
- Type in the number of the Windows installation you want to repair
(usually 1), then press ENTER.
- Type in the Administrator password (leave blank if you are unsure
what it is) and press ENTER.
- At the command prompt type
cd erdnt
or whatever you named your restore folder, then press ENTER.
- If you enabled automatic registry backup on system boot during ERUNT
installation and want to restore one of these backups, type
cd autobackup <ENTER>
- If you created subfolders for different registry backups (for
example, with the different creation dates), type
dir <ENTER>
to see a list of available folders, then type
cd foldername <ENTER>
where foldername is the name of a folder listed by the dir command,
to open that folder.
- Now type
batch erdnt.con <ENTER>
to restore the system registry from that folder.
- Type
exit <ENTER>
and remove the CD from the CD-ROM drive. The system will now reboot
with the restored registry.
ERDNT knows two restoration modes. The right mode is usually auto-
detected each time ERDNT is run, but read on if you are experiencing
problems restoring the registry.
"NT" mode is used if you run the ERDNT program from within the same
system where you made the backup. This is determined by looking at the
[SystemRoot] entry in the ERDNT.INF file and comparing it to the
actual %SystemRoot% system variable. Using "NT" mode is the only way
to successfully restore the active registry of the currently running
OS.
"File copy" mode is used if the currently running OS is NOT NT-based,
or if the [SystemRoot] entry does not match the %SystemRoot% variable.
In this mode the backed up registry files are simply copied back to
their original location.
MS-DOS based ERDNT only supports "File copy" mode.
Note: In restoration mode "NT" backups of the current registry files
are automatically created, so that option is grayed out. In
restoration mode "File copy" all saved user registries are
automatically restored, so you cannot choose between "current user"
and "other user" registries.
The backups of the current registry files are placed in the same
location as the original and are given the extension ".bak".
Experienced users don't even need to use the ERDNT program in other
operating systems to restore a registry backup. Given access to the
appropriate files and folders, the backed up files can simply be
copied back to their original location, as that is all ERDNT does
in "File copy" mode anyway. Have a look at the ERDNT.INF file to
find out what the original file locations are.
ERDNT command line switches
The ERDNT program also supports command line switches for "silent"
operation. The syntax for the ERDNT command line is:
ERDNT silent [sysreg] [curuser] [otherusers]
[/mode:nt|filecopy] [/nobackup] [/noprogresswindow] [/reboot]
(Switches in brackets are optional.)
silent
Puts ERDNT into "silent" mode and enables all other switches.
sysreg
Restore the system registry
curuser *
Restore the current user registry
(This option is ignored in "File copy" restoration mode.)
otherusers
Restore other saved user registries
line, ERDNT automatically uses the default restoration options, system
/mode:nt or /mode:filecopy *
Disables automatic detection of the correct restoration mode and
uses mode "NT" or "File copy" instead.
/nobackup
Don't make backups of the current registry files during restoration.
(This switch is ignored in "NT" restoration mode.)
/noprogresswindow
Hides the progress window during restoration.
/reboot *
Automatically reboots the computer when restoration of the registry
is complete.
* = Not supported in the DOS version of ERDNT.
Optimizing the registry with NTREGOPT
Similar to Windows 9x/Me, the registry files in an NT-based system
can become fragmented over time, occupying more space on your hard
disk than necessary and decreasing overall performance. You should
use the NTREGOPT utility regularly, but especially after installing
or uninstalling a program, to minimize the size of the registry files
and optimize registry access.
The program works by recreating each registry hive "from scratch",
thus removing any slack space that may be left from previously
modified or deleted keys.
Note that the program does NOT change the contents of the registry in
any way, nor does it physically defrag the registry files on the drive
(as the PageDefrag program from SysInternals does). The optimization
done by NTREGOPT is simply compacting the registry hives to the
minimum size possible.
To optimize your registry, simply run NTREGOPT, click "OK", and when
the process is complete click "OK" to reboot the computer. You should
do so immediately because any changes made to the registry after
NTREGOPT has been run are lost after the reboot.
NTREGOPT command line switches
The syntax for the NTREGOPT command line is:
NTREGOPT silent [/noprogresswindow] [/reboot]
silent
Puts NTREGOPT into "silent" mode and enables the other switches.
/noprogresswindow
Hides the progress window during optimization.
/reboot
Automatically reboots the computer when optimization of the registry
is complete.
Known problems
ERUNT and NTREGOPT sometimes fail with error 1450 when trying to save
a registry hive. I have not yet been able to reproduce this error,
which means "Insufficient system resources exist to complete the
requested service", on any PC, and reports from affected users
indicate that it also pops up when trying to back up the critical hive
using Microsoft's REGBACK program. This makes it unlikely that there
is anything I can do on my (the programmer's) side. Some users
reported however that they were able to work around the problem by
running ERUNT/NTREGOPT in Windows' safe mode, and in one case
uninstalling a Symantec software suite solved it permanently.
When the system is rebooted after a restoration of the registry with
ERDNT or optimization with NTREGOPT, Windows Server 2003 will by
default display the shutdown event tracker during logon asking why the
system has been shut down unexpectedly. This is because the info that
the shutdown was in fact an expected one is written to the "old"
registry during shutdown of the system which is replaced by the
restored/optimized registry next time the system is booted, and
therefore the shutdown info is discarded and shutdown event tracker
thinks the system crashed. You may want to disable the tracker to
avoid this message in the future (see the Windows help for information
on how to do this).
If you experience any other problems, please email me at
[email protected] with a detailed description and I will see if
I can help you.
Localization
You can translate all programs from this package into your language by
editing the appropriate .LOC file.
Keep in mind that the LOC files of the three Windows programs (ERUNT,
ERDNTWIN, NTREGOPT) should be edited using a Windows based editor
(Notepad), and ERDNTDOS.LOC using an MS-DOS based editor (EDIT.COM).
This is to ensure that any OEM characters are displayed correctly in
the program.
If your language is not yet present on my homepage and you want your
localization to be available to the general public, you are welcome to
send the four translated files to me. I will then make them available
for download, with credits of course.
I have included a German language pack. If you want to use the program
in German, simply unzip LOC_GER.ZIP into your ERUNT folder.
Version history
v1.1h, 03/06/2005
- Updated homepage address
- New ERUNT.INI option: AppendTimeToFolderEditField
- Fixed a problem where the current user registry could not be
identified on some systems
- Changed behavior of AutoBackup's /days:n switch
v1.1g, 11/02/2004
- ERUNT is now MUCH faster on Windows XP and Server 2003
- Added time string support on the command line
- AutoBackup now by default skips creating a backup for the current
day if one already exists
v1.1f, 08/26/2004
- Added AUTOBACK.EXE command line tool for automated registry backup
and deletion of old restore folders created prior to a specific
number of days
- Window position is now screen center instead of desktop center,
fixing display problem when using multiple monitors (thanks John :)
v1.1e, 07/31/2004
- Appearance of the date string can be configured via ERUNT.INI
- NTREGOPT: Optimization results: use thousand separator
v1.1d, 07/07/2004
- Optimized error handling
- Combined DOS and Windows ERDNT into a single Win32 executable,
fixing problems with the previous 16-bit exe stub on some systems
and with BartPE
- Added Windows Recovery Console support with ERDNT batch file
- Default destination folder can now be configured via file ERUNT.INI,
replacing #DestinationFolder command line option
- Changed the default destination folder to be inside the Windows
folder, for easy recovery console access
- New folder named the current date is automatically appended to
destination folder (can be disabled in ERUNT.INI)
- Rewrote major parts of the documentation
v1.1c, 05/10/2004
- Fixed problems with dynamic disks
- Added browse function for destination folder, as well as the option
to change the default name (use #DestinationFolder on the command
line)
- Re-added support for Windows NT 3.51 (got lost with v1.1) except
browse function
v1.1b, 04/23/2004
- ERUNT and NTREGOPT are now compatible with Windows Server 2003 and
Windows XP Service Pack 2
- Fixed a problem where the registry hives could not be
saved/restored/optimized on some systems
- Changed naming convention for user subfolders in the ERDNT folder
v1.1a, 10/03/2002
v1.1, 09/25/2002
- Fixed "Invalid pointer operation" message which occurred on some
systems (many thanks to Russ Cordner for his assistance in isolating
the problem)
- Fixed "Error opening localization file" message when ERUNT.EXE was
called from outside the ERUNT folder
- Fixed some problems with UNC path names
- Added command line support for ERDNT and NTREGOPT
- NTREGOPT: show optimization results (initial and new registry size)
v1.0, 11/24/2001
- Initial release
Disclaimer
The ERUNT package (including the programs ERUNT, AUTOBACK, ERDNT and
NTREGOPT) is freeware. Please pass it to anyone who you think may find
it useful.
I explicitly allow this package to be included in any file archive,
CD-ROM or other media collection as long as all files remain
unchanged. A quick note via e-mail where my program has been included
is appreciated.
Donations
Several people have expressed their wish to donate money for ERUNT and
NTREGOPT. Though I chose to make my programs freeware so that no one
is required to pay for using them, I understand and appreciate that
users want to honor my work by making a donation.
For this reason I have signed up with PayPal, a service which allows
you to easily send me any amount of money you like. So, if you find my
programs helpful, and want to make a donation, simply visit my
homepage and click the "PayPal" button, or donate directly to my
e-mail address via PayPal. Thanks in advance! Any donation is greatly
appreciated.
If you live in Germany and want to make a donation, you may also
transfer money directly to my bank account. Contact me for more
information.
One final word
Use this software at your own risk. I do not take responsibility for
anything that might happen to you or the PC upon use of my programs,
including but not limited to: registry destruction, hard disk crash,
heart attack...
Comments and suggestions via e-mail, however, are always welcome!
Brian
Premium Member
Discussion Starter #3
Thanks Bob.. tried that, didn't make a difference. Tried unistalling and reinstalling OE, didn't make a difference. Then, decided to do a google search for the error number it returned. Originally, it did say unknown error, then it returned an error number. This is the same problem here:Error number that I was experienceing. I dl'd the inbox as they suggested, OE recreates it upon bootup. Now, email dl's fine, I just can't delete anything!! <sigh> Back to the drawing board.
Brian
Hi
Give this a shot
Download WinSock XP Fix from see below
http://www.accessdiver.com/download/winsockxpfix.zip
Read this link
http://helpdesk.wisc.edu/news.php?id=562
or from:
WinSock XP Fix
http://www.spychecker.com/program/winsockxpfix.html
http://www.spychecker.com/download/download_winsockxpfix.html
How To Diagnose and Test TCP
How To Diagnose and Test TCP/IP or NetBIOS Network Connections in Windows 2000
see below
http://support.microsoft.com/default.aspx?scid=kb;en-us;300986&sd=tech
http://www.practicallynetworked.com/sharing/testtcpip.htm
Plus this link
Windows STOP/Error numbers Messages
http://aumha.org/win5/kbestop.htm
Also do this
download HiJack This ver.1.99.1
Use this program with care it will take out many items.
For the advance computer user.
download from:
http://www.majorgeeks.com/download3155.html
Also read the one below
http://www.help2go.com/article153.html
Or from
http://tools.radiosplace.com/HijackThis.exe
ver. 1.91
http://research.pestpatrol.com/HowTo/How_To_Clear_a_Hijack.asp
ONCE YOU HAVE THE LOG FILE USE THIS SITE TO
Help You ANALYZE IT.......,see below
http://hijackthis.de/index.php?langselect=english
Post it at
Read the Web Page when it pops up
If you are NOT sure don't check the item to be removed
READ,READ,READ
When your done go back and do it one more time
to make sure you got them all...
NOTE***it will make a back up so you can put them
back in if you need to,,,see desktop for folder and files
Brian
Premium Member
BrianS, win xp should do a "prepare error report", this is automatic. If it isn't, then something in the files has either been moved or removed.
You may also try reinstalling win xp. This should overwrite any errors.
Premium Member
Discussion Starter #6
I solved it!! Somehow, the deleted files file got corrupt and wouldn't allow me to accept certain emails. No, it doesn't make any sense to me either, I could delete one email, but not the next. In any event, I deleted the deleted files file and everything seems to be OK again. Now to run all my spyware and antivirus prgs to make sure nothing else is hiding here.
Thanks for all your suggestions.
Brian
Premium Member
Glad to hear you got it fixed. :)
1 - 7 of 7 Posts
