Hello to all members of Router Forums. This is my first posting. I consider my skill level between a novice and an intermediate. I live outside of Houston, TX and among other things enjoy my time in the wood shop.
I am seeking advise as how to approach the repair of an oval mirror opening on a circa 1810 sideboard.
The oval mirror opening is missing a small arch section which I need to make. The edge of the entire opening has a decorative molding cut as if a router with a molding bit was used. (Don't believe the craftsmen back then had routers.) I believe I have identified a router bit from MLCS called Heirloom bit #7880 that may match the original molding design. I have removed the mirror which may be used to make a pattern. I have also attached pics of the sideboard.
I am looking for advise as to the steps I need to follow to repair the edge of the mirror opening so it will look original. Hopefully your advise will also include how to hold a small piece while routing the arch, the edge and calculating the degrees in the arch. The wood is mahogany.
I have table mounted router and hand held routers along with other wood working machines and tools.
