If it has adaptive clearing, I'm in!!! 🙂
This is what is says:
"Toolpath optimization
With conventional machining, the feed rate is set at a constant speed determined by the most demanding aspect of the toolpath. The Optimize Feed Rates option analyses the toolpaths created in Carveco and adjusts the feed rate to give a constant rate of material removal. Benefits include:
A higher feed rate for lighter cuts and air moves, enabling faster machining.
A more consistent cutting-tool load, reducing machining-spindle and tool wear. This also produces a better surface finish, which improves quality and reduces the time and cost of hand-finishing .
A reduction in the feed rate as the cutter enters and leaves the material, which reduces tooling costs and the need to fit replacements. Similarly, protecting the machine tool reduces maintenance costs and limits down time.
A reduced need for manual adjustment of the feed rate and a reduced need for operator supervision."
That sounds a lot like adaptive clearing to me.
