1 - 9 of 9 Posts
· Registered
Hello everyone. I’m trying to finish a game board made of aspen. I need to number about sixty blocks 1-10. Each block, so far, has been sanded and coated with two coats of min wax “warm gloss” polyurethane.
I purchased a few colored acrylic hobby paints and also have spray paint and a stencil to try to paint these numbers. So far they bleed into the grain and under the stencil pretty bad. Ideally they would have been routed/carved/cncd but I’m sticking with the paint for now. Any tips?
I’ve tried taping and even clamping the stencil to the project to create a tight fit but the bleed still occurs. I’ve also tried using “mod podge” which is a crafting glue type substance to create a seal under the paint and it still looks kind of rough after.
Sorry if this is more of a crafting/hobby type question but I figured someone might know of a sealer or better method to pull this off.
· Registered
You might have better luck using large numbers on rubber stamps. Don't over ink them or use excessive paint. Start here: Large Rubber Numbers Stamp Set Diary Stamp 10pcs - Etsy
Another option would be to spray a temporary adhesive on the back side of the stencil so it sticks tight to the block. Removable spray adhesive by Scotch is one product that works well. The idea is to seal the edges of the stencil to the block so the paint can't seep under it. It's capilary acton that sucks the paint under the stencil. The adhesive may stop the seepage. Worth a try, you can get the removable adhesive spray cans for the big box stores. May need refreshing. Also, consider spraying the top and underside of the stencil with a clear sealer so your paint doesn't soak through.
· Registered
Discussion Starter · #5 ·
Thanks for the advice. I had not at all considered rubber stamps - I’ll keep that in my back pocket!
· Registered
Sand the blocks. Spray on some shellac 2 coats let them dry last coat at least a few hours and then carve and paint them with acrylic paint. Lightly sand and they come out really crisp. Blow them off and spray a clear coat over them.
Also I have used sanding them, spray shellac, then let that dry and then carve them and then color them in with sharpie and then wipe them off with some denatured alcohol and then seal with finish.
· Registered
1 - 9 of 9 Posts
