Hi All,
I don`t know if it is allowed to use brand names on this forum? I want to purchase a panelraising bit set, to make shaker doors, which is the best, Sommerfeld or Katana? The Sommerfeld setup looks quite easy as it comes with a small rubber grommet and all the bits are the same height, so you set up once and then simply change the different bits as needed. Does the Katana sets work in the same way, and what about quality differences between the two? This is the first time I`m looking at panel raising and I do not know what to look out for. Any help will be appreciated. Since we have a very limited range available over here, I`ll probably have to import.
Thank you
Thank you
