I have or had (haven't seen it in a while) one made by Sears. I found the script letters a while back (sheets of paper with the abc's in a script style).BAMILLER said:Has anyone ever made signs with a pantograph. I have one but am not sure how to use it. Any advice would be appreciated.
Take a look at this post and see if yours looks like mine:Billwolley said:Hi Bamiller -
I recently discovered this site and I've been reading through a lot of messages. Are you talking about Sears Route-A-Form? I have not used this for years but I do still have one. I made animals for the kids when they were small and I've had it since around 1970. Yes - My kids are now older than 35. WOW - that means my first router is really old. The route-a-form takes a bit of setup but I remember it to be fairly simple once you get past the setup.
I can e-mail you the 4 page owners manual of that's what you need? I hope that helps. I scanned the owners manual into an Adobe Acrobat format (.PDF) which for some reason I can not attach to this note.
My email address is [email protected].
Bill
Shawn could you take a picture of your set-up and how you move from letter to letter? I did this some years back but was not happy trying to get the letter to letter spacing to look right and since I've dug mine out I'd like to try again.shawn said:The signs are easy to make and very outstanding when using the old english template letters.
you will need a bench area about 4 feet deep and a extended 2x2 foot board from the table to put your letters on so your stylus arm hangs over the table.on to the board.
Then here is the tricky part...when you are setting up the letters,they have to be square with the center on=f the arms and the router bit has to be in the center of the board and when you change letters you have to put the router into the lower right dot.on letter pge and then pull out the letter,then insert the new letter and then loosen the clamps of the board and then slide down the board and router on board at same time to left handed dot on new letter..seeems like a olot but it only takes a a minute or two once you have the hang of it.
