The post on parametric designs got me back playing with making patterns. They are extremely fast and easy to make (once you know your software relatively well and know the techniques in making them, which there are many).
"Parametric design is a paradigm in design where the relationship between elements is used to manipulate and inform the design of complex geometries and structures.
Parametric modeling systems can be divided into two main types:
An easy way to create parametric designs is to use tessellation along with a 3d modeling physics engine modifier.
"A tessellation or tiling of a flat surface is the covering of a plane using one or more geometric shapes, called tiles, with no overlaps and no gaps. In mathematics, tessellations can be generalized to higher dimensions and a variety of geometries."
In Blender 3d you have the Tissue Tools built in add-on that does it automatically for you. So its a one push art piece once you have your foundation pieces built.
Below is a quick pattern I made (under a minute to make) using a plane and a modified cube. It does take longer to set it up as a grey scale depth map image because it needs to be rendered using a depth pass.
(Click for full size grey scale depth map image pattern)
What it looks like in my cnc software.
And in Blender 3d.
And what the model looks like with a wood texture applied.
I love making these pieces because the physical process of making them is so easy that you can focus on the look and feel of the piece. This is only one of many different ways to make these types of patterns.
Hope someone equally enjoys making them as well. And share pictures please.
- Propagation-based systems where one computes from known to unknowns with a dataflow model.
- Constraint systems which solve sets of continuous and discrete constraints.
And in Blender 3d.
