I have some bed legs that are cut with a slight radius and want to know how I do this with a table router. What do I need and whatever else
There will be about 1/2 inch curve to the outside of the leg and straight cut on inside of legfibertech said:Can you be a little more specific? There are lots of talented hobbyists here. Help is not far away. -Derek
If you're working in a table, the bearing on the top of the shank is mostly what you'd use - if out of the table, with the pattern on top of the workpiece, the bearing at the bottom of the shank is what you'd use. It just simply gives you the flexability to follow or mimic a finish edge that's either above or below the piece you're shaping.Jens Jensen said:I noticed that some have bearing on bottom of shank some on top what is with this
