Just bought a new PC model 690LR router. When I try to remove the motor from the base (1001), it rotates up until the upper pins in the motor are at the adjustment ring, but it won't lift out of the base. It moves up about a 16th of an inch or less and then feels like there is a pin, lower in the housing, that is catching on something. Any suggestions or insights?
