Welcome to the forum.
aWElcome to the forum.
That seems to be a fairly common complaint for that router, but I was not able to see a solution.
Can you take it out of the table and stand it 'right way up'?
Thank you.Welcome to the forum.
That's right! I had two table mounted and had the same problem with both. You have to remove it, blow it out with air, particularly around the screw gear and half nut strip, and slowly blow air around the housing while unscrewing the motor from the base with the fine adjuster. The problem is the half nut strip gets clogged with dust and won't clear the housing.a
Yes, that seems to be my next move. Going to be away for a week, so it will have to wait till I get back.
