phenolic sheet
20K views 10 replies 9 participants last post by  alan23
Where can you find large sheets of phenolic? I was looking for a sheet either 1/2 or 3/4 and 4'x8' if possible. I want to build my own router table top but also make a few jigs and use left over for sled runners.
Nearly any local source that supplies plastic, supplies laminate phenolic; it's not a hidden commodity but its specs' are!
Watch out for this stuff; it's not flat nor is its thickness uniform. In my view, for that, it is a lousy surface or jig substrate.
See mcmaster.com for a start.
Hi Shawn
My experience of machining them is that plastics normally don't come in 8 x 4ft sheets - the base size is much larger (often 3 metres x 1.5 or 2 metres) - although most phenolic stockists I've dealt with will saw to size. I'm not in the USA, but I'd suggest looking for "Engineering Plastics" or the like in Yellow Pages. Over here we have a manufactured brand called Tufnol and they do have distributors in the USA, including Complex Plastics Inc, although a quick email to Tufnol may furnish you with a nearer distributor.
One thing I will say is that you must have deep pockets because an 8 x 4ft sheet of 3/4in thick Tufnol is not going to be cheap (hundreds of dollars). It is more normal to use Tufnol to face another cheaper material, say a 3 or 6mm (1/8 or 1/4in) thick skin on 19mm (3/4in) plywood
Good luck with your searches
Regards
Phil
Counter top laminate works as well as anything you can find. It also makes good runners. The first set of cupboards I made for me and the missus was on a lean budget so I glued strips of laminate to the drawer bottoms and the drawer supports. Worked great. If they started getting sticky I just rubbed a little parafin (candle wax) on them.
#5 · (Edited)
Sheets of Phenolic Plywood for table tops
Hi Shawn,
I bought my phenolic top from Rockler.com. Should do the job. The photo shows the current pricing. The thicker 3/4" version would probably be flatter. A full 4x8 sheet would be hard to ship, would be expensive, and really hard to find.
Mark
ps
Rockler.com currently has free shipping for purchases over $25.
Hi Mark
Sorry to say it isn't. Quillman has it bang on. I used to CNC machine components out of it and where any real flatness was required I always had to surface mill it one side, then flip it over and do the other side before routing out components. I machined a replacement matrix bed for an old Wadkin CNC router that way on one occasion (50mm paper-re-inforced Tufnol) and what I did there was to bolt it onto the cast bed on the machine then face off the upper surface before milling all of the grooves out because of this flatness issue
Regards
Phil
#8 · (Edited)
Laminated tops work fine on a Router Table
John,
I have built 4 router tables from scratch to do specific things. And laminated tops and phenolic laminate all work fine. I don't have an idealized Super Incra setup, so I will never need the hundredths of a millimeter flatness that is suggested.
The words I homed in on were "router table".
Not CNC or a something needed to make a Hologram Table.
For all the fuss, I would opt for a laminate top as you suggested, for making a "Router Table".
And Cherryville Chuck also hit the nail on the head when he posted that "Counter top laminate works as well as anything you can find."
Mark
#10 · (Edited)
