1 - 16 of 16 Posts
I sure had fun with this project teaching my son-in-law some basic woodworking skills. Safe use of a chop saw and setting it up to make identical cuts and angled cuts. Measuring calculating and cutting angle braces. Gluing and assembling. He also learned the hard way how to clean out wood chips when drilling. He got a ½ inch Irwin Aggressive Bore bit stuck half way through 3 layers of 2X’s. It took two battery charges to get it unstuck. He successfully cleaned out the chips on the remaining holes though.
It took two afternoons to complete. The first to cut and build the frame and the second day to put on the tops. The top is 8 feet long X 33 ¾ + inches and the seats are 11 ¼. Sturdy and should last for years along with the skills he learned.
If you look close you can see the stuck bit in the first two pictures.
Discussion Starter · #3 ·
Very nice looking table. I like the recycled wood too.
Some lessons are learned well the first time.. He won't soon forget what it feels like when the bit is starting to plug up. I've seen them snap off when they are stuck that hard.I don't think they are as tough in reverse as they are in forward.
Nice looking table, but I am curious and must ask a question.
Why did you choose the angle the legs are fastened at?
I have found that when the foot of the legs do not meet the ground under the bench, there is a likely hood of the bench tipping over if there are people sitting on one side.
Just curious.
Discussion Starter · #14 ·
Just curious.
That is a good question.
There is enough weight on the other side that four big guys could set on one side. The fifth would cause a problem if no-one was on the other side.
One drawing I saw had the bench 14 inches away from the foot, I thought that was too much.
1 - 16 of 16 Posts
