1 - 8 of 8 Posts
Discussion Starter #1
Hi everyone,
I'm new to this forum but have been using a cnc router for years. I use different software but my main one is Rhino, my issue is when I draw out something say a circle or square it comes out smaller, about a 1/16". When I'm on the router and move it with the computer through mach111 (type in 10" say on the Y axis, it moves exactly 10") it is right on the money, but when cutting it's off.
I'm thinking it's in mach111 somewhere, a setting, a box that is or isn't checked, anyone have any ideas?
Thank you for any help
In your settings you should have a place to specify bit diameter. If the part is 1/16" small, my guess is that your actual bit size is 1/16" larger in diameter that the setting in your tool setup.
Welcome to the forum, Gary.
Hi everyone,
welcome to the forums Gary...
you are not compensating for bit diameter...
Ross
Welcome to the forum Gary.
G'day Gary, welcome to the forum.
Let is know if the above responses solve you problem. We have a separate section specializing in CNC issues....
1 - 8 of 8 Posts
