1 - 10 of 10 Posts
i need to make hundreds if not thousands of small parts that have curves. these will be around 2 inches wide x 3 inches long x 1/2 to 1 inch thick. is a smaller, modern pin router the way to do this? what brands or models would you suggest? and do these just use a normal router and the regular bits?
cordially
kevin yardley
diamond teak
215 453 2196
cordially
kevin yardley
diamond teak
215 453 2196
Hi Kevin:
I'll expound on one method but I hope others will add their opinions and experiences. This response is intended to push this topic back up the stack.
Take a 2"x3"x36" stick and using a router table, mold the curves in the length where you want. Then use a mitre saw to slice each piece off the stick. You may need to make a fixture to support the stick while cutting. A band saw would burn up less wood but a mitre saw would be quicker.
It would help if you could post some pictures so we could have a better idea of what you want (after your 10 postings)
Discussion Starter · #4 ·
these are wooden gun grips. i need to make a lot of these from very hard woods. and they are pretty small. a fellow who used to have some giant old pin routers told me this was the way to go. and that i could remove the material in a couple of steps. i may have a harvard degree. that doesn't mean i am smart!
cordially
kevin
Discussion Starter · #5 ·
A picture or two would be nice, you can post pictures right off the bat, so to say you don't need 10 posting to do so.:)
here's a picture of what i am trying to do. these blanks are at most 4 inches long x 2.5 inches wide x 1.5 inches thick. and they have lots of curves!
cordially
kevin
If you are making thousands of them, I would buy a small cnc router.
If it's hundreds, then probably making templates to use with your pin router is ok.
Hi Kevin
If you have that many to make I would job them out, many on the
CarveWright Users' Forum - Powered by vBulletin have made guns, you will see them on the forum in the gallery, many on the forum will take the job on...I'm sure..
cordially
kevin
You are in luck. The fact that they have screw holes in them makes it a little easier. I have an old RL Carter pin router (OWWM - Photo Index - R. L. Carter Co., Inc. - ORS5A-1) that can use a newer router motor. There are a few pin routers out there that are larger, but don't use stock routers, and there are a few available like Shopsmith, that are lighter weight and use stock routers. You can run two small bolts through your pattern, the pattern board w/ handles, and your stock. Plunge a little each time you go around the pattern until complete. The insides can be done the same way.
to all the old timers
I'm having trouble trying to figure out the difference between the function of a pin router and a table mounted bit with a bearing on top. Both function with templates. However, you have to remember there is a substantial difference between a pin router and a pneumatic overarm router. The pin router and the bearing work in two dimensions whereas the pneumatic overarm will work, freehand, in three dimensions but not with a template.
I would reason that a template with a bearing on a flush trim bit would be more effective in small numbers, but I have to agree with Gav and others that large numbers would require a CNC machine.
Whatever you decide to work with, you're going to have to develop a process to develop the most proficient production with the highest quality product. That is the part I find most interesting.
Enjoy and keep us posted on your progress and methods.
1 - 10 of 10 Posts
