Plan for a router table circle jig
4.3K views 5 replies 4 participants last post by  Chris Curl
This is very simple, but I think it will be effective. It is basically just a t-track on a piece of 1/4" ply with 1/2" sides and a jam nut that can be used to secure a 1/4" threaded bolt from above.
There is a hole in the 1/4" ply at the end of the track for the bit to come through.
And it is long enough so you can clamp it to the table on both sides and then adjust the radius with the t-track.
Thoughts?
A simple idea, Chris.
The only downside that comes to mind is that the centre hole for the workpiece has to be large enough to accommodate the size of the lock nuts. Do you also intend to drill the 1/4 hole all the way through the work piece?
after using the lock nuts to secure the threaded rod in the track, they would come off.
for a thicker piece where i don't want to have the 1/4" center hole all the way through, i could use a short threaded rod that did not go all the way through.
Perhaps an easier way would be to use a piece of shelf support instead of T track. Mount the router on the end of the board then set the circle size by putting a finishing nail through one of the slots in the shelf support and then into the wood you are going to cut. The slots in the shelf supports are about 1/2" apart so unless you had to be exactly accurate it would be a quick set up. If you had to be dead on it would take a little more precision setting the nail.
