1 - 8 of 8 Posts
hello everyone. I am in need of a manual with parts list for A king Canada planer model kc-816 On the front of the planer it says "16 " Autoplaner" if anybody has this manual I would sure like to get a copy. Email would be the easiest. Thanks.
Robert Reid
Hi Robert....... If you go to the Router forums homepage (or click on the RouterForums.com logo at the top of this page) then scroll down to the General Woodworking section, you'll see "Power Tool Manuals" at the bottom of that section. I see a listing for King Canada there. I hope this helps. I've found a couple I needed there. Jim
King Canada 816C manual
Hi Robert
Did you find a manual? If so I would like to know where please, I just bought an 816C at an auction.
Bruce Clift
Hi Bruce, welcome to the forum.
Robert has not been back for 2 years.
As per Chessnut2, If you go to the Router forums homepage (or click on the RouterForums.com logo at the top of this page) then scroll down to the General Woodworking section, you'll see "Power Tool Manuals" at the bottom of that section. I see a listing for King Canada there.....
I checked and there isn't one yet but I have a 16" King, not sure if it's the same model, and I know I have the manual, I just have to find it and scan it first. In the meantime if you have questions just ask. I can suggest that you check to make sure the head is level from one side to the other. Mine wasn't from the factory. Although it will leave some snipe and chips out some hardwoods it will take a 1/8" bite out of a 2x10. Great if you have access to rough lumber.
Thanks James, I did check there yesterday buy couldn't see the correct model, I'll look again a bit harder. Love that quote (a long time favourite of mine) which goes right along with "Nothing round here is simple except the boss".
Cheers
Bruce
Ross
Welcome to the forum Bruce.
I'm working on it Bruce. I scanned all the pages as jpegs and I'm trying to figure out how to convert to a single pdf file if possible. I could email you all the jpeg images for now if you need them, there are almost 20 of them with the parts list which you would need to see if there are any differences from mine to yours.
Mine is a SA 380. The manual says 15" but it is actually 16" wide as I planed some 6 x 16 timbers for a friend once. It also is called an Autoplaner. There are several other brands that use the exact same castings that I've seen, such as Delta and Jet. It was manufactured by a company in Taiwan and sold under several labels. Mine will plane 2 x 10s on edge but others, and I think later models of the King, used shorter posts and will only do 6+". I've replaced one feed roller and had to level the head to the bed (it came from the factory out of adjustment) so I can walk you through the processes if needed.
1 - 8 of 8 Posts
