Bob,
I received my order yesterday, Monday... Got around to watching DVD today...
The DVD version is sure a lot easier to build than the paper plan!! I might do it that way with a guard that goes around the belt & motor a little better.
I called them... talked to the guy in the DVD...
I asked if he ever modified the coarser grits spacing so as not to take as much off in a pass... He said "Yes, all the time... I did it today, just raised the screws a little to just remove some saw marks from a piece."
I asked about changing the outfeed height vs the infeed to be more like a jointer...
He said "Cannot do it... you will always get snipe & you cannot get rid of it. He also said that once you get the feel of it, you will know just how fast to feed it to get a full even cut... He said he sanded a door feom 3/4" down to 1/4" at a Show and it stayed at uniform width the whole way through."
So, I'm not going to change infeed / outfeed... will keep it all flat as recommended.
I think I will also make the simple version as noted above... maybe with something on the bottom to anchor it to a top... I think I will also have a flat bottom and vacuum the sawdust occasionaly... Don't know yet... maybe I'll slant the bottom like they did.
At any rate, I don't think I can mess things up too bad...
I have some scrap formica that would give it a nice smooth top...
I'm thinking of doubling the top with 2 pcs of 3/4" ply to get 1 1/2" thick top like theirs.
The top appears, to me, to be the most important piece of the project... must be FLAT and SMOOTH.
I was also thinking of making a fence, clampable across the top, so edges could be sanded at a positive 90 degrees... or 45 degrees.
I got the Grizzly 1/2 H motor you mentioned... it's a little wider than the paper plans would allow... will modify to good coverage.
So far, I'm happy...
I've been fighting computer problems for the last few days (main reason I have not been around so much)... have to get that stuff all done so I can give a borrowed notebook back...
How do you like yours... so far... I see you changing back to a flat top...
