Looking for plans showing parts and materials for home-made router table lift that will be attached to Kreg router table plate. Any suggestions/guidance would be very much appreciated.
Thanks for that heads up. I’ll be sure to stay away from scissor jacks.I don't have any plans but whatever you build it needs to be capable of lifting the router in very very small increments. Something made out of a scissors jack is not what you're looking for.
Welcome aboard Mike. As mentioned a lift should be capable of making very fine increments while keeping the router motor level so it may need multiple acme screw type raisers working together. The finer the thread the more capable of finer adjustments. There are plans out there but you may find after all your time and effort that it just won't do, but maybe not.
“The finer the thread the more capable of finer adjustments. I’ll be sure to keep this in mind as I look for a diy plan for a router lift. Thanks.Welcome aboard Mike. As mentioned a lift should be capable of making very fine increments while keeping the router motor level so it may need multiple acme screw type raisers working together. The finer the thread the more capable of finer adjustments. There are plans out there but you may find after all your time and effort that it just won't do, but maybe not.
Check out WoodSmith's router liftLooking for plans showing parts and materials for home-made router table lift that will be attached to Kreg router table plate. Any suggestions/guidance would be very much appreciated.
