1 - 4 of 4 Posts
Discussion Starter #1
I am new to using routers . I got a fixed base Ryobi router . Can you buy a plunge base for most routers ? Or if I wont a plunge base will I have to get another router ?
It depends on the model of router you have. Most of the major brands have a model that can switch between a fixed and plunge base. If you router motor is not easily removed from the fixed base, then there likely is not a plunge base for it.
Discussion Starter #3
OK Thanks . My router has a lever that you flip and the motor comes off .
That sounds like the ryobi I got with the router/table combo.
I never got around to checking ryobi's web site to see if there was a plunge base available for it before I was surprised with a plunge router. Still not a 1/2" one, so I will need another router in the future. :)
1 - 4 of 4 Posts
