BB ply is great stuff because it has so many layers, each going crosswise to layer above and below. So it tends to stay flat. It also doesn't have any unfilled gaps the you discover later.
It comes in 5x5 sheets for the real stuff. There is an American made brand called Applewood ply that comes in 4x8 sheets.
For some projects the better quality "maple" surfaced ply at Home Depot is more than adequate, but it doesn't have as many layers and does have the internal voids. But for your use, it should be OK. You can buy smaller sized sheets, but take a straight edge with you to make sure it is still flat. Their precut sheets tend to be warped.
I must warn you that once you start using real, imported BB ply, you won't like working with the ordinary stuff.
The big thing about a shooting board is that you have really straight 45 and 90 degree angles on the holding pieces. Take great care in getting these angles just right. Be fussy.
