Porter Cable 6931 Plunge Base
11028 Views 7 Replies 5 Participants Last post by  jmichaud77
I just bought a used Porter Cable router with a 6931 Plunge Base. Does anyone have exprtise or an owners manual on PDF? I need to get a base plate and am going to look at Oak Park. Any other suggestions? -Derek
1 - 8 of 8 Posts
Hello Derek,
Look here Search for an Owners Manual, Hope this helps.
If by base plate you mean a mounting plate so you can use your router in a table then the Oak Park Vac-U-Plate is a popular choice. Rockler Woodworkings aluminum mounting plate is also popular. A Rousseau mounting plate is my weapon of choice. Any of these will serve you well. As far as your router, you should visit: www.portercable.com
You can register your serial number, get manuals in PDF format, new product information and monthly give aways.
You guys are awesome. I did exactly as you said and registered. I saved the PDF for whenever I need it.
I need to take my router to one of the Porter Cable factory stores in the Seattle area. I know Rockler can help me also.
Would you mind sharing this document if still available?
Hi Fibertech,
I just won this plunge base on eBay and I'm having trouble sourcing the user manual. If you still have the .pdf, would you mind uploading it so others like myself can get a copy of it.
Thanks & best regards!
John
Have expertise with the 6931.
Was in on some of the product screening when they produced this, the first PK.
And I was PC vendor supplying them with subbases for the fixed base PK (6931) partner.
Still make PC plates.
John, you will find the PC 690 series manuals in our router reference section in the Porter Cable sub section.
Thanks Mike,
Haven't spent enough time here at the site yet. But, most likely will once this base arrives.
Thanks!
1 - 8 of 8 Posts
