Welcome to the forum, Dave..
I built my CNC and am using 48v power supplies for much larger NEMA 34 stepper motors. As Albert said above that voltage will be just fine.Normally, a 48V dc supply is used with Nema 23s but since mine are larger, they are exceeding this by a little over 25%. Kind of far out of my safety margin.
I have yet to do this but I really want to give it a shot at some point. Seems like I've seen some guitar necks generated with F360 so you might find some samples to help with your design and CAD/CAM work.Now..... To figure out how to write cam for a complex component like a guitar neck.... That's a different story haha
Albert,Hi Dave,
Perhaps I can give you some insight to your situation.
First of all with regard to NEMA motor specs - the most useless value is the voltage. I dont even know why they bother including this in the spec sheets because it is simply the rated current divided by the phase resistance.
-snip-
Albert
Mike, I too was recommended using a 36V system for my NEMA23 425on/in @4amp motors. I bet I could have gotten away using 24V PSU with no issues. It would be an excellent experiment.I use a 36V 9amp power supply for my 4 motors, Nema23 382oz/in @ 3amps. I worked with an engineer at Automation Technologies to make sure this was appropriate when making my purchases. (Great company by the way, they even called to answer questions I had when I emailed them). The reason this works out is that you won't be in a situation where all 4 motors are pulling their full 3amps at any given time, so the total power draw will be under 9amps.
Possibly, as others have said the voltage is the least important number. It really is the amp amount that the steppers are able to draw from that power supply.Mike, I too was recommended using a 36V system for my NEMA23 425on/in @4amp motors. I bet I could have gotten away using 24V PSU with no issues. It would be an excellent experiment.
Rick
Phil, I agree to an extent. These H-bridge amplifiers are driven in class D which means the transistors are driven in full saturation using high frequency/high slew rate ON/OFF pulses. When saturated, these transistors have little voltage across them, hence they normally do not overheat even in the most demanding circumstances. Therefore, these amplifiers require little voltage to keep these transistors in saturation. The DC resistance across the motor is only part of the equation, more important is how much inductance the motor has. In layman's terms AC impedance is like resistance, but its value is dependent on frequency and inductance. So, at slow speeds the motor has lower impedance, requiring less voltage to maintain max current. At higher speeds the motor has higher impedance, requiring higher voltage to maintain the max current. Remember these are stepper motors and electrical power requirements are not defined by speed. Since fast speeds are only required for jogging, I think that for CNC router applications, a lower voltage PSU could be applied without consequence. As I mentioned, it's a worthwhile experiment.Voltage for your stepper drivers is just as important as current since power is the product of voltage times current. In fact, you want to use the highest voltage your drivers can safely take. The reason why stepper motor voltage ratings aren't import is that they are used to define the current based on Ohms Law. With modern stepper drivers, any voltage that your driver can handle is ok.
Until I actually take some measurements, my theory is purely conjecture. The reason I desire to pursue this is that I would like to use a TMC5160 Stepper drivers, but it is rated at [email protected] 3A. At the moment I have a set of No-Name Chinesium Stepper drivers (DM556 clone). The design is inherent to produce lots of unwanted noise that may lead to missteps, not to mention dwarf pulses. It claims it is rated at 5 amp, but I seriously do not think it can run 3.0 amp continuous. The TMC5160 is so silent that you can't hear the steppers even when jogging at full speed. So, when my spindle is creating 89dB of noise, I will be at ease knowing that my stepper motors are only making 40dB of noise. ;-)point well presented. a lower voltage (inadequate) power supply can and will limit the maximum speed of a stepper motor.
so on that note, if when purchasing (one-time) a power supply, would it not be best to purchase the one which will not (likely) become a limiting factor of the stepper motors capabilities?
my history is with servo's, and my cnc has servo's. also, i am not well educated on stepper engineering/values. so just asking...
A couple of points, slow speed simply isn't an issue. It is the higher speeds that are. Also, higher speed isn't just for rapids. If your machine is rigid enough to cut at 150 IPM, then you will want to have the power to do so. That means the highest voltage you can safely push through the drivers. And high inductance needs high voltage to get the speed you want. There are limits, though - the 32*sqrt(mH) noted above.Phil, I agree to an extent. These H-bridge amplifiers are driven in class D which means the transistors are driven in full saturation using high frequency/high slew rate ON/OFF pulses. When saturated, these transistors have little voltage across them, hence they normally do not overheat even in the most demanding circumstances. Therefore, these amplifiers require little voltage to keep these transistors in saturation. The DC resistance across the motor is only part of the equation, more important is how much inductance the motor has. In layman's terms AC impedance is like resistance, but its value is dependent on frequency and inductance. So, at slow speeds the motor has lower impedance, requiring less voltage to maintain max current. At higher speeds the motor has higher impedance, requiring higher voltage to maintain the max current. Remember these are stepper motors and electrical power requirements are not defined by speed. Since fast speeds are only required for jogging, I think that for CNC router applications, a lower voltage PSU could be applied without consequence. As I mentioned, it's a worthwhile experiment.
Regards,
Rick
Phil,A couple of points, slow speed simply isn't an issue. It is the higher speeds that are. Also, higher speed isn't just for rapids. If your machine is rigid enough to cut at 150 IPM, then you will want to have the power to do so. That means the highest voltage you can safely push through the drivers. And high inductance needs high voltage to get the speed you want. There are limits, though - the 32*sqrt(mH) noted above.
FWIW, rapids are important. Maybe not for a small 3018 style machine but once you get over about 24", jogging speed is important. Plus, rapid speed does effect run time.
And forced air cooling of drivers is super important. While you are right about mosfets in saturation, the transition zone has heating and higher voltages mean longer transition times. a couple of fans is cheap insurance.
