I found information on the post found at the following link that indicates there are adjustments that can be made to the guide posts on a PRL-V2 router lift. Can anyone please tell me where and how these adjustments can be made? My lift is pretty sticky when I have the router mounted, pretty smooth without router. I need to try to loosen the clamping pad but I don't see how the pads can affect the lift mechanism. Either way I would like info on these post adjustments Thanks!
Quote from post found at link below:
" I ended up having loosen the two guide posts and reseat them. This seems to have fixed the issue and the lift is now working very smoothly."
www.routerforums.com
PRL-V2 Router Lift
I've got a PC7518 & PRL-V2 router lift. So far, so good. I'm building a cabinet to set the top onto. Still good, lots of learning on this first project, but still good. I need to get the router lift mounted in the top, which, by the way, is a double layer of 3/4" Birch ply. I'm confusing...
