Hi,
I am new to the forum not sure if I can ask my question here.
MY SETUP: I have the Incra TS-LS Combo 2, the Router Table is on the right side of th Jet Pro Table Saw.
The Incra Mast-R-Lift II Router Lift, is fitted to the Incra Router Table. The Router is AUK WM1800 MkII - 1800 watt fixed.
The Mast lift plate is leveled with 10 Grub Screws, I have no problems with leveling the plate I always check
the plate before using the router, I have been making raised panels on 12mm MDF with the CTM Raised panel set.
However after routing only 3 or 4 sides of the panel, the plate becomes uneven by 2mm to 3mm also on
the last 2 occasions 2 Grub Screws actually worked their way to the bottom of the plate and dislodged.
I have done very little work with this router setup may 5 to 10 hours.
Appreciate any help.
