Had and been using my cncest 6040 4 axis 1.5kw CNC for like 2 months, then out of nowhere when I go to use it from computer and start the spindle, it whines but doesn't spin. Yes I can turn the spindle manually while it is winding but will not spin even with that "help" (thinking maybe it was stuck but no)
I reset the control bow, but to no avail. Tried turning the spindle on in both PC mode and manual mode with same result. I assume the spindle windings are bad but I wanted to ohm out the wiring from the spindle connection to the control box. This is where I need help (and if you think there is something else I am missing to cause this).
There are 4 lead holes on spindle connection and 5 on the control box side. I put one probe in each hole of the control side (5 holes) and checked each of the 4 connections on spindle side. Only 2 of the 5 holes on control side gave a reading of connectivity with one (different one for each of the 2) of the 4 holes on spindle side.
My guess would of been 4 of the connections on control side would of had their own connectivity reading with their own on spindle side. Maybe I am wrong, not sure.
none of the wiring is tight, I don't see any signs of pulling, wear, or tear in the wire. Just want to rule it out before I go buying a new spindle.
Also, if I have to buy a new spindle. I am curious as to can I upgrade both the control box and spindle in one shot. This is a 4 axis so it does have an A axis. along with this question goes the obvious question of could I use existing wiring for that upgrade.
I cannot reach the seller any longer. Ignoring my emails. Don't know how to reach any mfg of this unit. Don't see a part storefront so basically on my own I guess..
