Hi,
When you buy bits they come in various lengths. When inserted in the router you do not want the bit in so far that it bottoms out in the chuck/collet nor do you want the bit in so deep as to get in the area of the bit where there is a transition to the cutting area (fillet). Most chucks/collets are designed to work with about 3/4" of bit in the collet/chuck. In a lot of cases you are told to bottom the bit then come back out 1/16" or 1/8" but if the bits are short that might method might not work... (Some bits are also marked with the amount that should be inserted).
I don't think the router has a problem but I don't own a Dewalt so maybe someone who does can comment.
Ed
Ed
