Problems with Flattening Jig setup
3897 Views 35 Replies 10 Participants Last post by  reuelt
Hello All,
Brand new to this forum, wish I had known it existed previously as it might've saved me a lot of heartache. I am an amateur woodworker and make a lot of epoxy wood river tables that require surface flattening after the epoxy has cured. After trying to make several of my own router sled jigs, I decided to invest in a very nice set up from clear-cut woodworking (photos attached). Their set-up requires a collet extension in order to clear the sled that holds the router. Unfortunately, I have been having all sorts of problems with vibration, the spoiler bit bouncing up and down, and gouging of my stock over and over again. I seem to be gliding along without any issues, then suddenly the bit will descend into the wood and gouge a new path (or worse). I read on a previous post that sometimes the extension can bend or slip within the collet. I have tried to tighten it down as hard as I can but it still seems to want to bounce up and down within the extension bit.
I know in general people recommend avoiding the extensions, but this set-up requires it in order to clear the rails. Any suggestions would be very welcome, as I've spent quite a bit of money on this set up. Thanks!
Road surface Wood Track Asphalt Composite material
Wood Trunk Grey Art Artifact
1 - 20 of 36 Posts
Welcome to the forum.
Hello All,
View attachment 402645 View attachment 402646
I tried to find clear-cut woodworking but Mr. Google is of tonight. My thought(s) is a design flaw meaning the flaw is depending on an collet extension for extended flawless accuracy for flattening a large project. The jig looks solid. I would try raising the material to be flattened high enough to avoid having to use a collet extension
Oops, I meant clean cut. Here is the link to the product.
They specifically state that you need a collet extension for the set-up to work.
“The Clean Cut Woodworking Router Sled REQUIRES a collet extension so you can attach your bit to the router. This 1/2" collet extension has been proven to offer the most balanced and strong hold for your router bit. Fits 1/2" shank bits only. Extend the depth of your bits up to 2-1/4. Overall diameter is 1-3/16"
I'd contact the manufacturer. Question. When the bit drops, does only the bit and shank drop, or does the extension and bit drop together. One suggests that extension's collet is faulty, the second suggests the router's collet is bad. The difference between loose and tight for collets is a couple of thousandths, so if one or the other is damaged in some way, or lubricated, or one is tight and the other loose, that could be the issue.
I also notice you are using a DeWalt, which has that ring height adjustment and I wonder if that is slipping somehow? When I shopped for routers, I noticed the only broken one on display was the DeWalt, and it was that ring that was damaged. Check for damaged threads or other slop in the height adjustment. I don't have a DeWalt, so I don't know if has a height lock or is just friction that holds the adjustment ring.
I guess if the router is old, you could have a problem with a bearing, any wobble/vibration might be loosening the collets. My thoughts at any rate.
Finally, it looks like you might be using a flat bit, which could easily catch and pull the bit loose. Consider using a bowl carving bit with a flat area, but rounded so it won't catch. You just make more passes. A bit something like this 1 1/4 Whiteside.
Cosmetics Tool Tints and shades Rectangle Cylinder
Welcome to the forum @jsorof
Thanks so much for the detailed reply and questions. Your comment about the DeWalt is interesting. After multiple gouges of the wood, I removed the router assembly and watched it just spinning from the side. Even though everything was supposedly tightened down and locked, I observed the entire bit assembly moving up and down even though the bit itself had not come loose in the collet. The height adjustment ring was rotating freely. Time for a new router for this set up?
If that's happening, a new router is pretty much your only option. Give consideration to the Bosch 1617 EVSPK outfit, which has both fixed and plunge base, each of which permits setting the bit height and locking it in. It comes with 1/4 and 1/2 inch collets in the USA. Excellent router, especially if you only have one. Get the kit, buying the plunge base later is pricey. Here's the kit.
Camera accessory Audio equipment Gas Cylinder Microphone
This router works really well in a table, and there are many great accessories, including dust collection. Two faves are the edge guide which doubles as a circle cutting guide (comes with dust collection parts), and the under table base for about $60. RA1165, with a key to do fine height adjustment from above the table. Dandy little accessories totaling less than $100 last time I checked. Lots of RFfolks swear by their1617s.
Gas Machine Electric blue Liquid Metal
This is the edge guide. Fancy devil and it shows where the bars go for a router ski. Over engineered? Yup.
Font Machine Auto part Computer monitor accessory Kitchen appliance accessory
Awesome, thank you. I will likely go out and buy that Bosch router. Unfortunately, I still will need the bit extender because the clean cut woodworking set up requires it.
Although it seems that you've determined the culprit (the height adjustment ring), I wonder if you could put the sled on upside down, hanging from the bars. That might bring the bit close enough, that you wouldn't need an extender??? Like Marco mentioned, it seems your work is too far from the router.
You may or may not need the extender. Try without first.
That is a really interesting idea and could very well work. I checked the setup and I can definitely flip the router sled. I just would have to prop up the rails on the side to get just the right amount of clearance.
Well, unfortunately flipping over the sled isn't a workable option. The spacing of the gliders that attach to the horizontal bars are not wide enough to accommodate attaching the router base to the sled. It does not appear to me that there is going to be any option other than the bit extender.
Too bad. I was wondering about that.
Get a new router, put 2 1/4" high slats between the sleds rails and store the extension in the bottom drawer.
4
Hello All,
1. You place the wood directly on the tabletop/bench. I recommend placing a 3/4" piece of flat plywood with adjustable feet on the bench. It will always allow you to keep your routing piece leveled and will allow you to elevate/adjust the height of the piece.
2.The cradle that your router is mounted to isn't built correctly. The router sits too high on the tracks, you need a new type of cradle. This is how I built it.
Very cool, Garen. So you bought the entire cleancut set-up but custom-made your own cradle for the sled? Would be very appreciative if you could PM me on your plan for how you did that.
I would love to get rid of the extension. I'm not sure though what you are proposing. The problem with the current set up is that even with the bit as low as possible within the router holder, the bottom of a standard bit does not go low enough to make contact with the wood because of the large amount of clearance between the bottom of the plexiglass cradle and the top of the rails.
Actually, I built it from the scratch. I bought two sets of rails with bearing blocks for $80, one 1/8" metal plate, and four pieces of 2" steel corners, about 10" long each, and put everything together. I don't make blueprints, but I can upload pictures for you to get an idea.
I saw that possibility as well.
As for collet extension; it will double or more any run-out from the router. I have one and in either one of my Craftsman 1/2" routers it vibrated and I did not trust it to be used heavily.
Later I bought a PC 7518 and tried the extension again. What a difference, in the 7518 it performed perfectly and felt safe to use.
1 - 20 of 36 Posts
