Here is the scenario that I want to do and what I’ve done.
I need a circle with 10cm diameter and 1cm whole in the center. The raw material is plywood with 18mm thickness and aspire software as G-code generator.
For doing this job , first I drill the 1mm whole with 18mm height and then use "profile tool-path" for cutting the outside of circle .
For cutting exp 100 circles in one sheet , with nesting function I've arranged all circles. Now I select all 100 wholes and drill them ( job 1) and then select all 100 circles and cut the outsides ( job 2) .
The problem is : job 1 needs a hour (exp) to complete and job 2 need 2 hours. Anything may happen during these 3 hours ( bit problem, human failure , .... ) and resuming is not easy with DSP controller.
I want to know that is it possible to define operating like this :
Drill the first circle's whole and then cut the outside of first circle ( complete first object ) and then all circles one by one ( but using sth like nesting for auto arranging these jobs in one sheet )
