Hi: The fence is removed when you are going to use a template and a cutter with a bearing guide to route material in other than a straight line. The safety pin is used to
provide a solid point to allow the template and material to be cut to get to the bearing
and the cutter. If not used the cutter would have a tendency to pull the template, the material, and possibly your hand through the bit. Hope this helps, Woodnut65
