Hi Bob
I think the collect size is 21mm but I don't have Hatachi to tell you for sure what size the lock key size is..
But open up the tool box and crab some open end metic wrenchs and slip it on the shaft that will tell you for sure what size it is.
Like you I'm still making my new router table, the link below will show you how to get around without playing with the lock under the table.
A real pain,,, the link below (John ) use some threaded rod but I think I'm going to use a cable setup so I can pop out the router via. the router plate in the top.
In that way I can flip the router around to use the big side on the table top.
But no fastners just a "z hook cable", so the parts don't have a chance to fall into the router and I can unhook it quick and easy if needed.
I did buy two offset wrenchs from Sommerfeld tools for the P.C. but I forgot I needed one for the Freud 3 1/4 HP router so I just made one from a old set I had on hand.
The collet,,,,,,I know someone ask the same thing about 2 or 3 weeks back ,but I could not find it with a quick search on the forum,Lee Valley rings a bell for the part (collet) you need.
"Marc Sommerfeld has added a wire control on the shaft lock for his super router table"
Hatachi router
John Lucas way below
http://www.woodshopdemos.com/cmt-jr7.htm
http://www.woodshopdemos.com/cmt-jr6.htm
If you are asking what the heck is a Z hook bend cable.
This a control cable you can make quick and easy with the right tool, it's just some 1/4' KEY stock that you drill a 1/32 hole in the end to make the tool.
see snapshots below,,,you just push the cable in a 1/32" hole and with just a quick turn of the tool you have a Z cable,then just push and turn it in and it's locked in the hole...Used on many lawn mowers and small eng. equipment, no fastners needed to hold it in.
Bj
