1 - 20 of 23 Posts
Discussion Starter #1
My quart can of penetrating oil is empty. I think Stick recommends acetone and ATF Dextron at 1:1.
I guess this is still the best for penetrating oil?
If Stick says it's good it is good.
He wasn't the only one that has tried it if I remember the responses correctly. It seems to me several people said that it works as well as anything they've tried.
that it is....
only better and my father will agree w/ you...
Ha! My mind went to Penetral. Oh that would work so well (not!) Of course, Penetrol hardens, which just might not be a good thing, when trying to loosen stuff.
I look forward to hearing more on this hack.
Reactions: Roy Drake
Well I am of the opinion that this is the very best. Of coarse you have to try it to find out.
Google Deal
Discussion Starter #11
I had a quart of Dextron III which I used for the mixing. I hope it is OK. None of my vehicles use the non synthetic Dextron. Even my manual 5 speed truck uses synthetic ATF in fact it requires 100% synthetic.
I seem to be working lots of old machinery so I think this will be a good cheap solution for penetrating oil. The Acetone is $4.50 per quart at Walmart and the Dextron was free since it was a left over.
You weren't going to reuse that part anyway were you Herb?
Reactions: Herb Stoops
So do I buy the ESP,M2C-33F,F ATF,ESW,M2C-33, Type G ATF,Dextron series, Mercon series?
Or just use a hack saw and cut it off.
hot wrench...
go to the auto section in any store...
buy any ATF by price...
1 - 20 of 23 Posts
